Question about HP OfficeJet 7410 All-In-One InkJet Printer
Picture print When I scan then print a picture, the picture has horizontal light lines about 1/4 inch thick all thru the picture
  • HP Master
  • 4,338 Answers
Read and do the diagnostic steps on this HP link:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=391193&prodTypeId=18972&prodSeriesId=391193&objectID=c00712074
Copy and paste the whole link into your browser.
Let me know the outcome.
If it helped, please rate it.
If not, I will research it some more.
Joe
Posted on Nov 21, 2008
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
There is a horizontal line in the mid
Hello
The vertical scan of your TV has failed. All picture tube type TVs have both horizontal and vertical scan sections to scan the picture on the secreen. When horizontal scan fails, you will see a vertical line at the middle of the screen, and if vertical scan fails, there will be a horizontal line through the middle of the screen. In your TV, the second stated has happened.
This may be due to an IC trouble or a voltage loss inside the printed circuit board of your TV. To rectify this fault you have to open your TV, and locate the vertical output section inside it. It is very easy to locate that section. There will be four wires goes from the deflection yoke; the coil fitted at the neck of the picture tube; out ot which, two will be thick and the other two will be thin. The thick wires are usually colour coded as red and blue. Colour coding may differ from set to set. Anyway you have to follow the tow thin wires, as they are carrying vertical scan signal to the yoke.
Following it, you will reach to a plug in point on the printed circuit board. Upside down the printed circuit board, and follow the track through which that wire connection goes, and finally you will reach to the vertical output section.
There may be transistors or IC used on that section. First check the voltage at the vertical output section. Voltage lose also may occur in this section. If it uses IC, check for any loose or bad solderings at the terminals of the IC. I advice you to resoder the suspected points by applying a little more solder, without shorting the terminals. In most cases this will solve the problem. If there is voltage, and there is no loose solderings and still the fault perists, replace the IC or transistors, whatever it may be, with same type and number.
If you want anymore asistance, fee free to contact me through Fixya. OK.
Dec 27, 2010 | Toshiba CF30F40 30" TV
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Vertical Thick Lines accross papaer on a HP Laserjet 3330
So the "White lines" went away when you replaced the cartridge, and now you have "dark Lines"?
It sounds to me like you have yet another bad cartridge. Is it remanufactured/ compatible?
Although, they can perform very well, they can also be awful depending on the source.
Return it and get another one, or different brand.
Jun 19, 2009 | HP LaserJet 3330 All-In-One Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
