Question about Plumbing
Water leaking from top of RO system.
I have a Kenmore Universal Reverse Osmosis home drinking water system, Model No. 625.347030. The system is 10 years old.
Water is streaming out of a small hole in the top of the RO cap. The water isn't dripping out of the hole, but rather is a fully developed low pressure stream of water. The hole that I am referring to is located in the top of the RO cap and near the base of the threaded cap of the shut off assembly. The water is not coming from the base of the RO cap where it interfaces with the RO housing.
I have replaced the following parts of the shutoff assembly: the top threaded cap, o-ring, diaphragms, and the plunger. It is still leaking water from the top of the RO cap.
The term name for the parts I am describing come from the Repair Parts list and schematic drawing. I hope this additional information is helpful in solving the problem. Can you recommend how I proceed to stop the leak? If the leak cannot be fixed, is the solution to buy new RO system?
Don Gerkin
480-312-7903
  • 19 more comments
  • dgerkin Nov 18, 2008
    There is no internal float. There is an automatic shutoff valve which activates when the bladder is full of product water; A check valve that prevents the backward flow of product water from the storage area to the membrane; a Flow control cartridge.
    There are no cracks in the cap. Water is coming out of a manufactured hole in the top of the RO cap.
    Yes, I replace the RO membrane regulary, the existing one is only one year old.
    I need a more specific solution.
  • dgerkin Nov 19, 2008
    I replaced the flow control cartridge last week with a new one and a new screen, but it is still leaking. The water is still streaming out of the hole is the RO cap that is associated with the automatic shutoff assembly.
    There is no plug for the hole.
    I have already tried those fixes, but it is still leaking out on top of the RO cap.
    Thanks, I already have this manual.
    Thanks, I already replaced the o-ring with a new one, and I've reassembled the automatic shut off at least 3 times now. But it's still leaking.
    Where is faucet vent hole located? This unit is leaking from the hole in the top of the RO cap.
    I already have the manual.
    I already did that. I need a more specific solution.
    That was my initial solution. I have triple check this and I still have the leak.
    I tried that 3 times already, and it still leaks.
  • dgerkin Nov 20, 2008
    I already checked for clogging. None found and water flows unrestricted through the lines.
    No lines are clogged, water is flowing unrestricted in all lines.
    I already have a manual.
    I'm trying this forum first.
    There is no leak at the faucet vent hole or obstruction in the line. If you think Kenmore techs can be helpful, please call them. I not aware of a Kenmore Tech helpline.
There is a crack in the cap of the automatic shutoff assembly or one or both of your diaphragms are leaking, meaning they may be worn or have a hole. One way to check this is to line the diaphragms with Vaseline and reassemble. Remember; the smallest hole will allow water to come out of the emergency drain hole. : )
Posted on Feb 15, 2010
    Sergeant:
    Champion:
  • 283 Answers
Check the delivery valve. Replace its rubber cap. Please dont rate me if you are not satisfied with my suggestions. Hope this could help a lot. Thank you.....
Posted on Nov 21, 2008
  • 685 Answers
I'm looking at the owners manual and it looks like its time for a new one not sure if you have the manual or nor here is the site i hope this will help you http://www.kenmorewater.com/website/customer-assist/manuals/625.347030.pdf
Posted on Nov 20, 2008
  • 68 Answers
You might have a clog in the line or around the faucets hope this helps
    Sergeant:
  • 229 Answers
To repair this problem refer to diagram # 10 in the manual you have. Reassemble everything exactly according to this diagram and the leak should be resolved. This should help. Good Luck
Posted on Nov 19, 2008
    President:
  • 1,901 Answers
My first thought is to make sure all of the parts in the shutoff assembly are aligned EXACTLY as the manual describes...holes and notches...then make sure the cap is tightened to align the mark on it with the arrow on the RO cap. Do not overtighten it.
    Sergeant:
    Champion:
  • 200 Answers
Hi
Check it this
it will guide u clearly
click
thank you
  • Thafa Nov 19, 2008
    Hi
    Using the manual reassemble the device...Before reassemble check all the seals are in good condition and then check separately each device so that u can find where is the problem...And then tight everything properly..
    Thank you
    Genius:
  • 1,550 Answers
  • Push tube into fitting past “O” ring seal.
  • Cut damaged area from tube or replace tube
  • Remove “O” ring and inspect “O” ring groove for debris. Clean groove, lube, and reseat “O” ring.
  • Reroute tubing so tubing runs vertically with no sharp bends or loops. (Cut off excess 3/8 tubing so that tube runs "downhill" to drain)
Disconnect drain tube and clean out restriction. (Food particles from garbage disposal).
    Genius:
  • 2,035 Answers
Please click here and get the service manual....
Good luck..
  • 10,515 Answers
Hey dude,
Refer to this lik for the explanation :-
http://www.flintandwalling.com/RO_troubleshootingindex.htm
Any issues................
*********************************24/7 available**************************************
Take Care Bro.
  • taran_2005
    taran_2005 Nov 19, 2008
    If the sink p-trap is used as the drain point, RO reject water is routed to the faucet air-gap through 1/4" tubing. It gravity drains from the faucet through 3/8" tubing to the drain point. The hole in the faucet body, below the lever, is the air-gap vent. If the 3/8" tubing is restricted in any way, reject water will backup and leak from the faucet vent hole. Thoroughly clean the tubing and the p-trap fitting if leakage occurs at the vent hole
    ********************TRY THIS*****************************
  • taran_2005
    taran_2005 Nov 20, 2008
    Hey buddy,
    Why dont u check directly with them.
    The link wld be :-
    http://www.kenmore.com/shc/s/nb_10154_12...
    b'coz we have already provided u all the possible reasons. And believe me nw kenmore is the only one who cld find tis as over the internet we cannot c ur water purifier.
    If u wish i wld glad to talk to them and discuss and wld be able to tell u.
    Thnx.
  • 1,543 Answers
Have you tried to clean out the flow control (part #7167764 Ref #25 on diagram)? It is inside the tube at the end where it comes off the RO cap (and goes to the air gap). Take a fine wire and poke it through the flow control to remove any blockage. This may do the trick.
Posted on Nov 18, 2008
  • 147 Answers
Sounds like you might have a small clog in tank cell or line cousing a backflow
  • Joshua Davis Nov 20, 2008
    then it sounds like its time for a new one
    Sergeant:
    Champion:
  • 435 Answers
Did you replace/ service the RO membranes regularly ?
If not, may be its developing high pressure to cause the leak.
    Scholar:
  • 181 Answers
Can you see any slight cracks near to the cap .if there r then its leaking from that crack.check out that.
  • 4,806 Answers
Is there an internal float that is stuck allowing overflow?
  • Lee Hodgson
    Lee Hodgson Nov 18, 2008
    ahhhh the overflow cap/bung is missing :)
    regards
  • Lee Hodgson
    i always thought that these "manufactured holes" were to test the water temperature, could be wrong but is not conceivable that there might be a "plug" for this hole?
    regards
Microorganism class 8 question answer
No. The filters sold for faucet application are not certified to remove microorganisms removal from raw water to make it safe to drink. Even a reverse osmosis (RO) membrane isn't certified for microorganism removal to protect health. Although the RO membrane pore size is small enough to filter out parasites, cysts, bacteria, and viruses, there is always a potential for a breach in the membrane. To remove microorganisms from a raw water source you need to add an NSF/ANSI Standard 55 Class-A certified ultraviolet disinfection system.
Apr 10, 2014 | Camping, Backpacking & Hiking
Why can't I use reverse osmosis water in my mini-Keurig?
Because you take off of the impurity's out and it changes the qualities of the water..
heatman101
Jul 17, 2011 | Keurig B70 Coffee Maker
Leaks on the top of black box of culligan water softner under sink system
Is this a reverse osmosis drinking water system? If it is it is an H8 RO. If so shut the water off that feeds the RO. The leak is probably coming from one of the fittings, they can be cut by the compression fittings and leak.
RJ
Feb 13, 2011 | Culligan Under Sink Water Filter
I want to unhook my reverse osmosis how do u do that and what are the steps
Here are the steps to remove your RO system. Put a pan and a couple rags under sink to catch any water that might spill.
1. Label all the lines from RO (with masking tape) to remember where they go.
2. Turn the water off to RO system
3. Run all the water from the RO tank
4. Turn the valve off on RO tank.
5. Remove the line to the RO tank and pull tank out.
6. Remove the line to the RO drain.
a. If there is an AIR GAP faucet this line may go there first
b. plug the whole for RO drain or replace the standpipe
7. Remove the product line from RO faucet
8. Remove the water line feeding the RO system.
9. Make sure the valve feeding RO is shut off completely
a. If this valve is a piercing valve you may want to consider replacing the section of copper
plumbing because it will eventually leak if left unused.
10. When re-installing the RO remove old filters, sanitize system and replace with new filters.
RJ
Nov 11, 2010 | Culligan Under Sink Water Filter
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
How do you know if you need to replace the RO membrane filter in the culligan good water machine
A TDS (total dissolved solids)meter is needed to test the Reverse Osmosis water and compare it to the feed water to determine how much TDS is being removed. Reverse osmosis membranes are designed to remove 80-95% of the TDS in your water supply.
For example: If your water has 500ppm of TDS the minimum TDS removal should be 400ppm leaving 100ppm. If the TDS from the Reverse Osmosis System drops to these levels it is time to change the Membrane.
Typically an RO system will consistently remove 90+% of TDS for many years. The normal lifespan for a membrane can be anywhere from 3-10 years. It all depends on the TDS of your water and your water usage. The higher the TDS the more frequently the membrane needs replacing. The other filters should be replaced every 6 months to keep the quality up and protect the membrane.
A TDS of 1000ppm compared to 100ppm is much more difficult remove to acceptable levels. I like to compare 1000TDS to taking muddy water, forcing it through a filter and getting drinking water. Where 100TDS may be more like a clear glass of water. Consequently a reverse osmosis system on high TDS will be less efficient, less gallons produced and filters will need to be changed more frequently to keep the quality and quantity up.
RJ
Oct 04, 2010 | Culligan Under Sink Water Filter
I have a GE PROFILE R/O System with a chrome dispenser; I need a brushed nickel dispense; where can I get one???
An RO drinking water air gap faucet would be the ideal faucet to purchase for your RO system. Here are a few options you can choose from that may come in brushed nickel: http://www.freshwatersystems.com/c-821-ro-drinking-water-air-gap-faucets.aspx
Jul 31, 2010 | General Electric Profile Smartwater Ultra...
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
A drain tube in the water dispensing module constantly has some water flow. What is the purpose of this drain and how can I eliminate the water loss.
A reverse osmosis system drinking water system will waste a certain amount of water for every gallon it produces.
1. The higher the TDS (total dissolved solids) the higher the ratio of waste water to product water.
IE: An RO on TDS of 1000ppm may require 7 or more gallons of water to waste to 1 gallon of product water. TDS of 100ppm will have about 3 gallons of waste to each gallon produced.
2. It also depends on the Membrane capacity. Membranes for residential RO systems come sized from 7-75 gallons per day. If you are a heavy water user and have a low producing membrane the RO may not shut off until it gets to rest at night and fill the tank.
3. There can also be a problem with the automatic shutoff on the RO. When the tank fills up and the pressure equalizes across the system the ASO (which is just a simple diaphram system) shuts the water off to the system.
4. If there is not enough pressure in the RO tank the tank may fill up but there may not be enough back pressure to shut the ASO off. So the waste and product water go down the drain and it runs constantly.
RJ
May 21, 2010 | Culligan Under Sink Water Filter
Which is the best RO system to use for an LG side-by-side fridge?
You realize you asked a simple question for a very complex answer. Water supply is the first key and that water supply depends if the reverse osmosis has been applied there before reaching your refrigerator. I can name many countries where the water you see you cannot drink but only purchase purified water. If you have clean and safe drinking water in your home then use the recommended filter that LG reccomends. If not then I recommend Omni Pure. Thanks, Sea Breeze
http://www.omnipure.com/
Dec 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Plumbing Logo
1,182 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
