Question about Asko 24 in. D3120 Dishwasher
Asko d3120 flashing coffee cup
Asko d3120 has flashing coffee cup. Some sort of motor or pump running continuously. Tub empty? Even when I open the dishwasher, the motor or pump noise just keeps going, and when I close the dishwasher, the coffee cup just keeps flashing.
The owner's manual refers to error codes F1-F6, but this dishwasher does not seem to have anything on it that could indicate any of these codes. Does anyone know what the flashing coffee cup means?
  • 3 more comments
  • ckeefe30 Nov 29, 2008
    the cup keeps flashing and the pump stays on with door open
  • sally24 Jan 02, 2009
    Flashing cup. Drain cycle continues endlessly. Need to unplug to get the machine to stop
  • robyoko Jan 06, 2009
    I have this flashing coffee cup problem. The drain motor is still going even though the mail power switch is off.
  • tizi Feb 04, 2009
    Same problem flashing coffee cup and pump on all time.
  • nuttbar Feb 23, 2009
    pump stays running with power off
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Posted on Feb 13, 2009
The float switch or sensor seems to be stuck or tricked by the water in the tray below which is making the pump run continuously. I slid the washer out, removed the back panel, and mopped up all the water from underneath. When I plugged it back in the dishwasher worked as normal. What caused the leak I still have no idea.
Posted on Apr 28, 2009
Your trick works. I pulled the unit out and tipped it, while being careful not to break the attached hoses, and this reset the unit.
Posted on Feb 10, 2010
    New Friend:
Thanks, solution worked for me too. Dishwasher pump would continuously run as if it was draining but no visible water left in bottom. also had the flashing cup. Turning off at wall did not work. Pulled the whole unit out and tipped it forward, water everywhere but removing the excess water worked! Works fine now. Cheers
Posted on Jul 28, 2013
Asko fifteen eighty five dishwasher completes cycle, but the drain cup area still has water in it.
The drain cup normally has water in it after it drains. The pump runs it empty, but when it stops, some water runs back down from the drain hose, which you see in the drain cup. If there is water in the bottom of the tub, you may be having some siphoning coming back after draining. Check to make sure the drain hose has been routed up to the bottom of the countertop as per the installation instructions. That's what prevents siphoning, and its very important so it doesn't suck sewer water back in with the clean dishes!!
Jul 08, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Asko 6762 does not complete filling with water. It also wont complete spin cycles. The drain pump sometimes runs continually after the tub is empty. Have cleared the coin trap and the hose between the tub...
Sound like it could be some "dirt" in the "air-trap-tube", so the machine dont get the signals that says it's empty. This also can also make problems for filling. This "air-trap" is the plastic tube, mounted upwards on the bellow hose, between drum and pump.
Could also be a pressure switch, or pressure sensor problem, but this is not very common:)
Oct 04, 2013 | Asko W6221 Front Load Washer
Hi Donald, Asko D3120 pump motor runs non stop.
Seems to be the fault with the control panel as it is possible that the drive relay stays triggered as soon as the power is switched on. All you need to is to remove the panel and check for a short in the power line output to the pump motor. Please check this link for tips to remove; Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html Use a multi-meter without which you will not be able to confirm the case. DO NOT BUY A NEW BOARD unless you have tested the board to confirm if the processor has failed or if this is a SCR or relay then it can be replaced.I would suggest that if there is a similar model with any contact or even from the service center where it can be swapped and tested or even tested on bench by simulation if you are familiar with the input connections.If none of the functions work then it is possible that the motherboard is faulty. Take estimate and decide.Compliments of the season.
Dec 28, 2011 | Dishwashers
Pump is always running on my Asko D3121 even when door is open. the pump works OK when I put water in dishwasher but never stop
check the float switch ... it is under the dishwasher it could be stuck in the up postioin or you can have water under the dishwasher..
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 16, 2008 | Asko 24 in. D3120 Dishwasher
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Asko 24 in. D3120 Dishwasher Logo
3,378 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
