Question about Bosch Dishwashers
When dishwasher cycle is started no water enters the dishwasher.Hoses and filters checked and all O.K.Power supply is on.
  • 41 Answers
Make sure water is on to dishwasher. second, check the float switch to make sure it is working properly. the float switch is located inside the dishwasher in the front. just lift up on the float and back down and make sure you can hear the switch clicking. try and run unit.
if that doesn't work, take of the bottom kick panel and remove the wires to the water valve. with an ohm meter on voltage, turn the dishwasher on and make sure there is proper voltage going to the water valve. if that is ok, either your water valve is plugged or bad. Joe
Posted on Nov 18, 2008
Neff s5443x1GB/29 dishwasher starts and stops
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 16, 2013 | Neff Dishwashers
It's asking to check water and won't start to wash
Guessing the water system is turned on and all velve open. There is an electic water inlet valve on the dishwasher, thet maybe clogged from sand in your water supply. The valve is located where the water enters the dishwasher on the buttom, the valve has a strainer filter that gets clogged sometimes. (if your not on a city water system this is a common problem) You will need to turn the power off to the dishwasher, and remove the inlet valve assembly(blue in color some machines) when you get the valve assembly out remove the inlet, and outlet hoses form it, check the inlet orafose for sand etc, and clean this in warm soapy water, even let it soak in a pan for a while. re assemble in reverse order, see if you get water into the dishwasher when you get it re-assembled and powered up.
Nov 06, 2012 | Dishwashers
The clean button blinks. the only button that works is the drain button.
Hello
Confirm that the door is closed and latched. dishwashers can detect if the door is open and will cancel any cleaning cycles to prevent water spillage. Wait for around 20 minutes before unplugging or moving the dishwasher in case the washer is cooling down, draining or drying dishes. Call a technician if the dryer does not restart.
Verify that a cycle has been selected using the "Cycles" button and that the "Start/Resume" button has been pressed. Unlike some models of dishwasher, appliances won't start until you select a cleaning cycle and press the "Start/Resume" button.
Confirm that the dishwasher's electrical outlet is switched on, if necessary, and that power is being supplied by plugging in a lamp. You may need to replace a fuse or reset a breaker on the electrical circuit if the lamp will not work in the outlet. Ensure that the dishwasher is plugged into the outlet.
Ensure that the water shutoff valves at the wall are open and that the supply hoses are free of kinks. Your washer will not start if it is unable to access the water supply. Most shutoff valves need to be turned clockwise or moved to the "Open" position to work properly.
Open the door and check the overfill float in the bottom of the dishwasher. Push it down to make sure it can move up and down freely. The machine will not start if the sensor is stuck at the top. The overfill float looks like a small cone on top of a disc with a paddle attached to the side.
Sep 12, 2011 | Whirlpool DU1055XTV 24 in Builtin...
The motor turns on but no water is entering the dishwasher to start the wash cycle.
Hello there
Here is the most common troubleshooting tips
Dishwasher does not fill with water or it drains while filling
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
  • Please check each one of these out carefully ok
  • Hope this is very helpful for you
  • Best regards michael
Jan 10, 2010 | Bosch Integra 300 Series SHX43C0xUC...
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
I have frigidaire dishwasher,starts cycle,can hear water entering dishwasher,checked level of water,does not get to 1",machine starts washing by the sound of motor, but dishes are not clean,water drains...
Depending on your dishwasher, it fills either by a timer or by a water probe or float. I will assume its a timer as a probe or float wouldnt exhibit this behaviour. I would say you have a restriction in your water supply line. Check your valves, any screen filter in the water line for sand/scale/silicate/etc, pressure regulator if applicable. Another posibility is a poor magnet in your fill valve.
Dec 19, 2009 | Frigidaire Dishwashers
Powder gets wet
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Mar 25, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher cycles but does not clean the dishes
if your dishwasher is cleaning poorly, check these: Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Nov 08, 2008 | GE Nautilus 24" Built-in Dishwasher
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
Dishwashers Logo
131 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
