Question about Dryers
Ge dde6500gbl electric dryer motor will not start
Dryer stopped working in dry cycle. Discovered that ground strap was broken(now replaced). Did not work. Discovered the spring loaded start button had a broken internal sliding part to start switch that when pressed closes the circuit to start the cycle and when released leaves the circuit open. When the slider was broken it left the circuit closed full time. (slider now repaired and functions properly). The door closed indicator has been tested with voltmeter and functions properly. The heater coils which are controled from part of the push to start switch heat properly. I used the voltmeter to test the cycle selector contacts and found resistance at 3 different locations with the dial in three different setting positions. I suppose the cycle setting dial is ok. I checked for blockage in the blower tubes and found no obstructions. Still, when plugged in, the motor makes no noise nor will it turn. I checked the wheel/armature of the motor for obstructions and it spun freely. I see no damage/burns on the motor from heat or wear. I just don't know what else to do or check to make this machine work. Please help!!!
  • sharpal1969 Nov 24, 2008
    Thanks for the solution- it worked! I found that the high temp limiter safety selonoid/fuse had and open in it. I replaced it and now works fine. Thanks again for the info!!
  • 324 Answers
Check your thermal fuse.this is on the heater housing.
Posted on Nov 19, 2008
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
Sep 05, 2012 | GE Dryers
Have a GE electric dryer model DJXR433EC2WW. Whenever I select the dryer mode/time option, the dryer turns on by itself without turning the start switch (door closed). The dryer only stops when it...
I have seen that in those dryers before and it has always been the motor that is causing it to start without engaging the start switch.
Sep 16, 2011 | GE Dryers
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Sep 27, 2010 | GE DCVH515EF Electric Dryer
The dryer (electrical) stop working every couple of minute and i have to push the start buttom over and over till having the load dry
If your dryer is more than 3 years old, this issue may be caused by a broken motor. Regardless it still working, the motor may continue with this problem until it stops working.
The only solution for this may be replacing the motor.
Oct 10, 2009 | Kenmore 62602 Electric Dryer
My electric GE dryer stopped working today, when
sounds like the motor is running, the belt could likely be broken and be the culprit, this is if the motor is turning for sure after you start the dryer
Sep 30, 2009 | GE Dryers
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer switch grinds and sometimes starts, most times not
Sounds like the overload switch is cutting out , my gues will be that the motor is going bad. Just replaced mine was doing the same thing.
Jan 20, 2009 | GE DBL333EA Electric Dryer
Dryer Stopped
Probably has a blown hi-limit fuse. Long dry times are often caused by restricted vent. Clean vent often. When vent is restricted it causes heat to build up in dryer and this blows hi-limit fuse. It's protecting your dryer from a possible fire. Location is dependent on model and gas or electric.
Oct 05, 2007 | Dryers
My Electric dryer will not start.
you might have something stuck in the impeller. if there isn't anything stuck, you might require a new motor
Jun 28, 2007 | GE DWXR483EBCC Electric Dryer
Dryers Logo
164 people viewed this question
Top Dryers Experts
