Question about HP LaserJet 3600n Printer
Cannot print 4x9 common envelope
Using iMac microsoft word...tray 1 HP laserjet does not print, keps reading "processing word-E" and data green light blinking
SOURCE: My HP laserjet 5p manual feed/ envelope tray
Solved
Posted on Feb 09, 2011
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
  • 526 Answers
SOURCE: I don't really have a problem, but questions about my HP Color LaserJet CM1312 MFP Series PCL 6. Can I print regular 4X6 glossy photos? and Is there an easier way to print envelopes that taking the pa
Tray 1 can support 3 x 5 to 8.5 x 14 in
the tray can also handle 10 envelopes.
there is no standard tray for envelopes only.
Posted on Apr 17, 2009
  • 121 Answers
SOURCE: I have an HP Color LaserJet 1600- I am trying to
Good day my dear friend i have hard thi kinda problem before what i did was to replace the printhead,which perfectly work out for me.so i think you should do the same thing too...hope to hear from you soon
Posted on Jul 06, 2009
FixinFax
  • 3085 Answers
SOURCE: HP Color LaserJet CM2320nf MFP Envelope wrinkles
trust me on this: ALL laser jet printers wrinkle envelopes; buy a cheap ink jet printer for envelopes
Posted on Jul 02, 2010
I am using hp 3505 color lesser printer on windows 7 32bit, Driver that was installed automatically by windows is "HP Color LaserJet CP3505 PCL6" My tray 1 that is multipurpose tray is printing slo
Make sure that you have tray 1 set for the correct paper type. Leaving the paper type as unknown will result in very slow printing as the printer will assume that it might be printing on heavy media, envelopes or the like.
Feb 02, 2015 | HP Office Equipment & Supplies
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
I have a HP LaserJet P3005 printer. I can't get it to print an envelope from tray 1. It used to work before -- not sure what happened. Please help!
In the printer properties ,,
select tray 1 as the source
select envelope as the type
for size set the size of the envelope
hit print..
Nov 12, 2010 | HP LaserJet P3005n Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Can't Print Envelopes, No Ink being used
Set tray 1 for the correct size envelopes in printer properties.
Feb 21, 2009 | HP LaserJet P2015dn Printer
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Printing Envelopes
Must use Tray 1 bpass to feed labels, on word change media type to envelopes ie page size,paper type and on printer set tray1 paper type to envelopes
Dec 11, 2007 | HP LaserJet 4100n Printer
HP LaserJet 3600n Printer Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
