Question about Kyocera Mita KM-2550 All-In-One Laser Printer
I can not get the fax to work on our Kyocera Mita CS-2550
I can not get the Register key to work. I am not sure what the problem is other then the fax just will not work. I have the fax line plugged in and It seem as if the machine has all ready been set up for faxing but it is still not working.
  • 523 Answers
Double check with the fax card if its really connected, coz usually when you cannot access to register key this means your fax card is not recognized yet, just unplug the fax card and plug it again, and check the status.
make sure you plug the phone line where it says line not T1 ot T2
and to know if your line work, hit fax buttom and then look to the screen and touch onhook buttom, if you heard the phone hook sound this means is working fine, if not check the fax card.
Regards
Posted on Mar 01, 2009
Kyocera km-2050 print mode error
Print Mode Error is Chenglish for a problem with printing. Press the Print key at the left side of the panel, then the display should tell you to add paper etc
Dec 31, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
Kyocera km 2550 error c0610
Replace the main PWB and check for correct
operation.
Oct 26, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
We have a KM 2550 copier and I am trying to get a manual free that tells me how to register a PROGRAM key (one step) to scan documents. The process is long and complicated and I need to register just one...
Hey is a link to the Kyocera website that will allow you to get all the manuals for this model for free.
http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=13703&pcat=10564&rcid=10009&rscid=10028&x=21&y=5#bottom
Hope this helps.
May 25, 2011 | Kyocera CS-2550 Black and White Copier
I want add a KM-2550 as a printer on an XP machine. I know what the host name of the KM-2550 is. The KM-2550 is definitely on the network because I pinged it from the XP. How do I find the name of the...
u can come to know from the server
where its physically installed
goto printers and faxes
then oen printer properties
and there is a tab named shared
see the name there
and write it
and then
u can add to the other macine
and can install
Jun 18, 2010 | Kyocera Mita KM-2550 All-In-One Laser...
I am trying to set up newtwork scanning on our Kyocera KM 2550 multifunction machine and I can't find in the manual how to do it?
cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
Dec 22, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
CS 2550 software
You can find the drivers for this unit at the Kyocera-Mita America website. Follow this link to the download section and find the appropriate drivers for your operating system. I would suggest using the KX Drivers as they are the most useful and offer the greatest control of the printer.
http://www.kyoceramita.com/download/
Choose your country and then find your model of system. You will see everything listed at KM series, these are the same devices just labeled as CS for the Copystar line of machines. Find the KM 2550 driver file and download the software and install it as you would any other printer in Window or Mac OS.
I was a Systems and Technical Sales Engineer for Kyocera-Mita for more than 6 years from 1998 - 2005 and worked extensively with the R&D Teams in Japan on the development of these systems.
Hope this gets you going.
Cheers,
Keith
Dec 02, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera mita long distance faxing
Kelly,
I hate to point out the obvious, but make sure your phone line has long distance service, then make sure you are dialing 1 before the long distance number. You didn't mention if you had to dial 9 to get out. If you do, you may have to enter a pause between the 9 and the 1. What model Kyocera Mita do you have? The fax kits vary by model, and I can look up any issues with your particular fax kit given the extra info. Thanks.
Bryan
Don't forget to rate your answers please.
Nov 27, 2007 | Office Equipment & Supplies
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
165 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
