Question about Frigidaire FRS23R4A Side by Side Refrigerator
Handle replacement for water dispenser
I own a Frigidaire FRS-23R4A and the handle on the water dispenser broke off. I bought the handle (actuator) but I have not found a way to get the front cover off where the ice/water dispenser sits to repair. I have tried taking the foam insulation opff that it's inside the freezer but did not see any screws. Does the cover snaps off from the inside? I have tried that unsucessfully too but I hate to break that off. Any suggestions would be much appreciated! phlip4life@sio.midco.net Thanks, Melissa
  • Melissa Phillips Dec 20, 2006
    Great Solution!!! Thanks for your help!!!
    President:
  • 878 Answers
Melissa, you don't get it from the inside. Remove the drip tray by pulling it out. You should see two screws holding the dispenser cover on each side of the bottom. Remove these screws and push up on the dispenser cover, there's 3 hooks on the top. Unplug the harness from the dispenser board and get the cover out of the way. Now is the hard part. You have to get at the module itself that holds the paddle. These can be a fight. If you go to Sears.com, go to appliance then parts and post your model number you should get a breakdown of the dispenser that will guide you. Catriver..post back
Posted on Dec 10, 2006
I need a replacement handle for water dispenser on FFUS2613LS
Sorry but this site has no parts resources of any kind. I suggest you contact Sears Direct, they service just about anything.
Jan 19, 2012 | Frigidaire FRS23R4A Side by Side...
Small leak on handle
Gaskets on this kind of faucets wear out often so you have to replace them, follow instructions
Fix a kohler faucet
most likely the gasket broke inside the lever, you have to replace it.
shut the water off from the angle stop (valve under the sink) both hot and cold.
use an allen wrench ("L" wrench) to remove the tiny screw around the lever, >>>>before you do that place a rag covering the drain for if you drop it<<<< after that pull the lever out, that will show the inside of the faucet. use an adjustable wrench to remove the actuator from the base. when you get that part out you should be able to see the damage to the gasket. At that point you need a phillips screwdriver to get the gasket out and back in >>>>take the damaged gasket to the hardware store<<<< and get a replacement you may have to change more than one. after you get all the gaskets in place, reinsert the actuator and don't forget to tight it up with the adjustable wrench. center it so it would dispense the same amount of hot and cold water, replace the lever reinsert the tiny screw with the "L" wrench. turn on water from angle valves and test faucet.
that should do it and save you about 300 bucks
if it works for you don't forget to rate me
May 10, 2010 | Moen 67430 Chateau Single Handle Kitchen...
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
No water from water dispenser
the valve or the outlet had been jammed. its an rare case. for this, wash out all the water from the dispenser and afterthat open it and fix the blockage.............
Jun 20, 2009 | Frigidaire FRS6R5EMB Side by Side...
Replace left front door outside handle pot metal tip broke off
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. NOTE: The tie strap does not need to be reinstalled.
    If equipped, remove the tie strap from the anti-theft guard.
  1. Remove the screws and position the anti-theft guard aside.
  1. Release the clip and disconnect the exterior door handle actuating rod.
  1. Remove the anti-theft guard.
  1. Remove the exterior door handle screw.
  1. Remove the exterior handle actuating rod.
  1. Remove the exterior door handle lock cylinder cover.
  1. Remove the exterior door handle.
Apr 25, 2009 | 2001 Ford Escape
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
How to replace water dispenser handle Frigidaire
HOW AND WHERE CAN I GET A NEW WATER DISPENSER HANDLE FOR A KENMORE 5567 SIDE BY SIDE FRIDGE,THANKS JERRY HUMPHREY
Sep 11, 2008 | Refrigerators
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
485 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
