Lexmark 6500 Wireless, stopped printing
Lexmark 6500 wireless, purchased Jan-Feb, installed on desktop w Vista. Worked beautifully. Last night it stopped obeying print command. Either did nothing at print command or said 'Printing Started, Printing Finished', but no printing occurred. Uninstalled X 3, no improvement. Went to my laptop with Lexmark 6500 wireless installed w Vista, picked a document, print command, printed beautifully.
  • jo53493 Feb 18, 2009
    I have same problem - printer randomely goes awal and wont work, tried re-installing, turning on and off etc etc, but still nothing. Occasionally it will decide to work again, but is so intermittant it truly affects my flow of work. Can someone help with this?
  • Anonymous Mar 03, 2009
    I also can't print to my Lexmark 6500. It also says printing started, then finished, but it never even sends it into the print que. I think this may have started with the last Vista update.
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
SOURCE: printer says printing document but will not print. anything
hp colour laser jet 2605dn printer is intialiazing but it is give not printing
Posted on Aug 30, 2008
SOURCE: Printer installation apparently successful, but doesn't print.
try completey removeing the software (even in the regestry) and then the driver, then get the driver again from the internet.
Posted on Sep 05, 2008
bluegreenash
  • 661 Answers
SOURCE: Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
Posted on May 25, 2009
ChobPT
  • 220 Answers
SOURCE: I have the Lexmark 4530 wireless printer My laptop
Make sure you sure your lexmark is set as the default printer under the Printers & Faxes option on control panel
Good luck
Posted on Jun 21, 2009
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Connecting the HP OfficeJet 6500 to wired & wireless computers
Use the disk that came with the printer and install the software in both the computers based on the os installed in the individual computers, ping the ip address of the printer from both the computers, and then test for the functionality
Jul 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Wireless print server
If your WEP encryption key is turned on, it will not work. To correct this, go into Internet Explorer and type in the IP address of the printer. Type in the WEP key in the correct place and save the information to the print server, then restart the search program.
There is a detailed thread I posted on this last July on Fixa. You should be able to find it by searching under the Linksys print server by the model number.
Nov 17, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark 6500 wireless printer does not print even though it is detected in the wireless network
-check your firewall, it might be blocking your printer or your network
-check also if the correct port is detected, just go to your printer and faxes and right click on your lexmark printer and click on properties, then under ports tab check your lexmark network port.
Aug 01, 2008 | Office Equipment & Supplies
Lexmark X1185 Not working with Vista
You might try downloading the Vista driver for your printer onto all of the computers on the network that have Vista...
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
Hope this helps
Jan 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Nov 19, 2007 | Lexmark X1150 All-In-One InkJet Printer
167 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
