Question about Zenith R57W46 57" Rear Projection Television
Zenith inteq 60'' picture adjustment
The picture on the tv is zoomed in, and blurry in the corners. i don't have the original remote control, and a universal one is unable to work with it. is there something that can be done to adjust the zoom? its also tilted slightly on an angle. sounds like it could be a big issue?
its actually a 60 inch. i can get the exact serial number if this problem sounds to difficult to make clarity
techman
  • 3130 Answers
SOURCE: universal RCA remote control
Your going to have to read the directions or owners manual and do a scan search. Its very easy. READ READ READ
Posted on Aug 13, 2006
jimbo4026
  • 50 Answers
SOURCE: zenith inteq 60 in rear projection coolant leak
I would check with LG/Zenith on this, there was a update sent out to add a collection cup in case this would happen. If leaked on the board it would be to costly on repair with the board is still available.
Posted on Nov 20, 2007
ctf1800
  • 4402 Answers
SOURCE: analog or digital?
http://www.ntia.doc.gov/
Posted on Jan 15, 2008
SOURCE: Zenith PVY6067DT Starsight - 1996 No Picture No Sound
i just bought one of these with the same problem and had a repair man come over. said it has a h.v. power supply problem even though the red light is on and some little board cant read the handwrighting on estimate but will follow up. must replace the whole board the power supply sits on, it is the big board that the power cord connects to in the back of the tv... other board it is located behind the little panel in between the speekers on the front it is the little one in the left hand top corner. parts/labor mainly parts +/-$500. is it worth it? ihave not seen this tv working so if there are any comments about the picture quality i woul like to hear/read them. hope this helps.
Posted on Feb 16, 2008
SOURCE: Zenith ZN110 Univesal Daewoo tv Code
a gpx dvd player
Posted on Apr 28, 2008
UNIVERSAL REMOTE CODE for SUPRA ST29K33F TV
Your question is very vague, but it sounds like the picture on the TV has faded away in the corners and probably looks like a circle in the center of the screen....? If so this has nothing to do with your remote control and everything to do with the TV . I would toss it and invest in a new flat screen. Don't waste money trying to repair TVs - they are now disposable items.
Jan 24, 2015 | Universal Televison & Video
Philips tv on zoom and no remote
To make picture to normal, you must have its original remote control.
Nov 04, 2012 | Televison & Video
I lost my remote to my sanyo plasma and my picture is stuck in zoom. I've already bought a universal remote that has a pic. zoom button but does not work for my tv. How can i get my picture down t
push minue directly on tv and seif that works. try to see if you can get it out of that mode. you might need the origanal remote. try search on the remote control may work
May 16, 2012 | Sanyo DP42746 42 in. Plasma Television
I lost my remote control tv-dvd thrutech model t2000d .what is code i can use universal remote conrol
U tries those codes that came with ur universal remote owner manual codes for ur tv model already.Those codes don't work for ur tv.Return the universal remote,because any codes people give will not work either.Try website like Remotes.com to buy the tv original remote.
Jun 09, 2011 | TruTech T2000D TV
I have 60 inch zenith inteq projection TV no picture or sound it powers up fine took it to a repair shop tech guy said that a whole board need to be replaced but the board is a discontinued item said it...
May be you went to the wrong place, find another repair shop where they work that brand and type of tv. Doubtless, some parts are discontinued, but they will take parts of another equipment that are dismantled. Good luck.
Oct 06, 2010 | Zenith R60V26 60" Rear Projection...
The picture on the screen in blurry
you might need to see if you can have a tv technician come and clean your mirror and crt guns. and yes universal remote will work fine
Mar 18, 2010 | JVC AV-48P575 48" Rear Projection...
Zenith tv picture is larger than screen
Hello
There are Horizontal and Vertical size controls behind the back cover that need to be adjusted using a hand held tool. This adjustment requires a trained tech. High Voltage from the set is dangerous.
However, there maybe some limited controls that may help through the on screen menu.
To get into the setup menu, you need the original Remote that came with the TV.
Hold the Menu Key down until a box appears in the corner of the screen, then press 9,8,7,6 Enter. this takes you to the service menu. Just scroll through the items to find Horiz Size and Vert Size.
Good luck
Dec 30, 2009 | Zenith H32G48S TV
New RCA RC246 remote with new RCA L40FHD41 TV. Dish remote won't adjust volume. Any ideas?
The Philips Universal Remote SRU4208WM/17 works with this TV. Must use the code learning feature.
Jul 12, 2009 | Universal Remote Control DIRECTV Universal...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
146 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
