Question about Neff Washing Machines
Dishwasher NEFF S5443X1GB/17 .. chalky residue, where and how do i add salt ?
    Genius:
  • 1,028 Answers
If you mean dishwasher probably you have hard water and residue is from buildup in unit ..try using a dishwasher cleaner like dishwashermagic ..after through cleaning try using white vinegar to keep build up down
Posted on Nov 19, 2008
How do i add salt to miele incognito?
There is a cap inside the dishwasher on the bottom right side, unscrew it and dump a full box of salt in. Clean up any spilled salt and run a rinse and hold cycle to remove any salt residue. Miele recommends using their own salt, available online at www.mieleusa.com or at a local Miele dealer. They don't recommend using water softener salt or table salt. For more help call their tech support at 800.999.1360, they are very helpful.
Mar 31, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
I Have a candy dishwasher about 4 years old after washing it seems to leave a gritty chalky residue I have tried added salt, rinse aid and putting a diswasher cleaning solution through it nothing seems to...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 13, 2011 | Candy CD623X Free-standing Dishwasher
My dishwasher has left a white residue on items on the top shelf I have put the dishwasher on the hottest wash, I have checked the rinse aid and the salt
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 05, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff s5443x1gb\29 my dishwasher is leaving the contents after a wash with a film of dirt. it looks like a film of dirty water which is dried on . i have put salt and rince aid in and have done 2 washes...
Useful tips for a clean plate,
Filters clean?
Rinceaid/salt topped up?
using the right detergent?
Have you run a full cycle with a named dishwasher cleaner?
I know it sounds like the obvious but above you will find what i think is the solution.
Jan 20, 2011 | Zanussi Dishwashers
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Chalky residue left on dishes
hi,
The chalky residue would have formed due to the washing liquid or powder used. According to my experience, I am happy with "Amway -Dishwasher liquid".Please try it for washing your dishes. It leaves no residues and even cleans your dishwasher. On continuous usage, you may find the difference. Overall, it cleans your dishes as well as washer simultaneously. Though its a bit expensive, it is worth buying it.
please search in "ebay" for your country to get the product. Please rate my solution as helpful. Regards, Venu.
Feb 18, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Modell S5443X1GB water not pumping out,no
First you need to ensure that the drain pump is working.
The drain pump is tested by the technician by energizing the pump directly, so to understand if the pump solenoid is working.
This is an unsafe job for the home user, as there is AC inside your appliance, all live power test should be done by techs.
Apart testing the pump, check also the wiring harness to the pump.
If the pump is fine, then replace the control panel.
Here you find parts for your appliance and repair help.
Mar 04, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher : accidentially put detergent(soap) into the salt compartment !!
You should be able to run it threw and not have an issue.
Just dont add anything else.
Sep 11, 2008 | Neff 24 in. S5409X0 Built-in Dishwasher
Dishwasher
Hi there.
Check salt and rinse-aid levels first. Often there is an indicator if either of these falls below a level.
When was the last time you filled them?
Top up rinse aid to mark, and add at least 1kg of salt.
Run M/c on a quick cycle and see if it's back to normal.
Hope this helps you.
Jun 14, 2008 | Dishwashers
Dish Washer
If you live in a hard water area the 5 in 1 tablets will only work half way. Consider Calgon powder or the tablets which can be left in the dishwasher cutlery basket as an additional measure. Hard water areas are notorious for leaving chalky residue on cutlery regardless of 3 in 1/5 in 1 tablet promises.
Also your dishwasher will require rinse aid too as most machines need this to mix in with the general water and soap solutions when the dishwasher is on its final rinse.
Apr 19, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Washing Machines Logo
395 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
