Question about Microsoft Xbox 360 Console
My son has XBOX 360 and it is showing error e74? do I need to send this in for repair?
    Novelist:
  • 100 Answers
E74 - There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see 0102 below).
0102 - Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard. There are two theories to fixing this. One deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips.
DO NOT attempt either of these, if your console is still under warranty. If your console is still under warranty, return it to the store where it was purchased or call Microsoft to have it replaced.
Posted on Nov 18, 2008
Xbox 360 e74
E74 Means your Graphic card damaged, Unfortunately there is no easy fix. either try to find a local xbox repair center or must send it to xbox directly
Thanks
1RepairStop.com
Dec 04, 2011 | Microsoft Xbox 360 Console
E74 error and flashing light on xbox 360
Your console has a general hardware failure, if your console is less than 3 years old, and has not been tampered with in any way, ie: the console has not been opened, microsoft will repair this FREE of charge,
visit www.xbox.com/support to book a repair.
Mar 09, 2010 | Microsoft Xbox 360 Console
E74 error message xbox 360
now this my friend is why you dont use an xbox.
My answer? get a ps3
Oct 14, 2009 | Microsoft Xbox 360 Console
How do i fix the x box 360 3 red rings of death
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 30, 2009 | Video Game Consoles & Games
X box 360 1 red light e74
This indicates overheating and could lead to terminal problems in the console... I would send it to MS for repair... also see this link if you like....
http://ezinearticles.com/?Xbox-360-E74-Error---Everything-You-Wanted-to-Know-About-Error-E74&id=2613185
Jul 28, 2009 | Microsoft Xbox 360 Console
Everytime i switch on it shows errror E74
The E74 error code occurs when the Xbox 360 console experiences a general hardware failure.
To confirm your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
If your console continues to display the E74 error message, it requires a repair.
Login at the following website to start an online repair support case
(Free repair if console is still under warranty, $99.00 if not)
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
or contact Xbox support at 1 800 4my xbox
(Free repair if console is still under warranty, $120.00 if not)
Jul 23, 2009 | Microsoft Xbox 360 Console
Xbox E 73 error
Hi Brett,
FYI. the 3yr extended warranty only applies for the 3RED LIGHTS and E74 issues only..if the console is already in the service center,you dont have to worry anymore,microsoft technicians will surely work hard to get it fixed. just wait 2-3weeks for the whole repair process,and you& your son will enjoy playing xbox in no time. :-)
May 15, 2009 | Microsoft Xbox 360 Console
My xbox 360 has frozen,and all it says is E74. How do I fix this?
Your machine has succumbed to the RROD RED RING OF DEATH error.
The Xbox 360 e74 is one of the many types of Xbox error codes that can affect your console at any given time. Thousands of Xbox 360 consoles worldwide are affected by these various errors, and one of the most common of them is the e74 Xbox error, which is currently affecting your console, as well as preventing you from gaming on it. Today you are going to learn what causes the Xbox e74 problem, as well as whether you can fix it yourself.
The e74 Xbox error's principal cause is overheating, due to excess heat causing damage to various components, and eventually major malfunctions in the hardware of your console. Why is this heat able to build up and cause damage that leads to the Xbox 360 e74 error? This is actually due to cramped case design and a lack of cooling devices such as fans and heat sinks. Although overheating is ususally a problem for all electronic devices, the Xbox 360 does seem to suffer particularly badly from this issue.
Although you could fix your Xbox e74 problem by sending your Xbox 360 back to Microsoft for repair, the best method you can actually employ is to fix your Xbox yourself.
Here's why-
* You will be without an Xbox 360 console for at least a couple of weeks if you send your console away for repair. Why put up with this when you can fix the Xbox 360 e74 issue yourself in a matter of hours?
* If your warranty has expired then you will have to pay to have your console repaired, and although there is a cost involved in purchasing the necessary items for Xbox repair, you will still save around $100 by carrying out the repairs yourself.
If you want to fix the Xbox e74 error yourself, then you will need to invest in a video repair guide. These come in digital download format, and can be purchased online for a reasonable price (you won't need to spend anything over $30) You really need to buy one if you want to fix your Xbox 360, as written instructions just aren't detailed enough.
To ensure that you get the best deal, purchase one that covers ALL Xbox error codes (many only offer information about the "red ring of death", so you need to carefully read the sales page to ensure that it teaches you how to fix any type of Xbox error) Look also for a money-back guarantee, free customer support and free video samples to that you can check the quality of the product.
Some have used damp towels to bring the temp down - but ultimately, the proper repair entails disassembly of the xbox - down to the processor - removing the old hard thermal paste compund, adding new thermal paste, and re-assembling.
There are MANY guides and videos you can search google for to crack open your 360 case if you are up to the challenge.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 05, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
52 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
