I have a washing machine that was made in mexico, the problem is the pump that send the water out is not working and I cant get a replacement, can I get a unverisal pump to match the one thats there ?
    Sergeant:
  • 276 Answers
Thats not possible to get a universal pump.
but you can ckeck out repair clinic webside for this pump.they will provide you the pump just enter the proper model number of your machine.you will see the pump with proper rate.u can also order the pump online.they will provide you.
Posted on Nov 18, 2008
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Hi, my washing machine is LENCO LWM-2651BJ my problem on my machine is when he reach to drain it go off and he cant drain the water, i bought this machine in israel and i send it to philippines and i dont...
    Possible that the drain valve/pump is faulty.Now this can be failure of the pump/valve or the pump is clogged with dirt and so does not work. You need to first check the voltages on the drain pump at the time of drain, if not present the program controller is faulty but if present the valve/pump is faulty. remove from the drain outlet hose fittings , remove the pump and clean or back-flush with jet water, test outside for the pump to work freely , if not the pump is faulty and must be replaced.
    Apr 23, 2011 | Washing Machines
    Cycle does not advance?
    it sounds to me like its a water pump problem i think you will find your water pump is not working. if the washer cant drain all its water it will not advance further than that as the machine must detect that all the water has been pumped out before it will start to spin. thus protecting the agitator from snapping.
    Jul 02, 2010 | GE WBSR3140DW Top Load Washer
    Bosh wasmachine doesn't was clothes
    Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
    Mar 23, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
    Started to wash, then stopped. wont spin
    turn water off and disconnect water hoses. there are small screens in water inlets where hoses attach. use a flat screw driver or something that will fit in the inlet to rake debris off of screens. if you cant get screens clean pull them out they are replacable.
    Jan 09, 2010 | Whirlpool Washing Machines
    CANT DRAIN OR SPIN WATER OUT OF MY WASHER
    you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
    Jan 29, 2009 | Washing Machines
    Water leaking from under the front of the washing machine
    The pump is easy to replace:
    #1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
    #2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
    #3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
    #4 Remove the 2 clamps off of the hoses.
    #5 Install the new pump into the hoses, and reinstall the clamps.
    #6 With the retaining clips installed into the motor housing, install the pump.
    #7 Attach the retaining clips, and set the washer back on the ground.
    You have now replaced the washer pump.
    If you have any questions, let me know
    Dec 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer problem
    It happens due to its malfunctioning. Water pump is not working at all. You need it to be repaired/replace!
    Dec 08, 2007 | Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
