Question about Canon PIXMA iP1700 InkJet Photo Printer
Paper won't feed
My printer at first was only feeding from one side and now it's not feeding the paper through at all? what should I do?
  • 1 more comment
  • Anonymous Nov 19, 2008
    Paper gets jammed on one side of the printer. I have done the maintenance - cleaning the rollers, nothing.
    Any suggestions to take it apart
  • Anonymous Jan 28, 2009
    Our printer is pulling in the paper on only the right side. We have tried many things to fix it. Any help?
  • mau_etop May 02, 2009
    i also have the same problem. my canon pixma ip1700 eats all my paper at once. (when i print, i place about 20 sheets of paper. my problem is that it eats about 5-10 pages, or sometimes everything, just to print the one page!) the solution i did is very stressful. Putting paper one by one so that the printer couldn't eat everything. this way even though it eats everything on the tray, it only got one paper. but then i repeat, ITS SO STRESSFUL especially when i'm printing a lot of pages.
    @gcr, i didn't get your point here..
    "put a large amount of paper into the feed tray so the infeed rollerswould pick it up, cut it back on the paper went thru and low and behold out poped a lemon seed"
    all i understood is to turn the printer off and put paper into the feed tray. please enlighten me. thank you!
  • 170 Answers
I know this sounds funny, but my Grandmother in law had the same problem, I turned the printer off, put a large amount of paper into the feed tray so the infeed rollers would pick it up, cut it back on the paper went thru and low and be hold out poped a lemon seed....
Hope this helps,
David
Posted on Mar 13, 2009
Printer problem
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 12, 2013 | Canon MX300 Office All-In-One Printer
Z42 not feeding paper
Regards,
Sanath
Feb 20, 2013 | Lexmark Color JetPrinter Z42 InkJet
Canon ip2600 won't feed paper
I fixed mine!! I cut a letter size paper in half lengthwise (so it was skinny and long). Held the printer on my lap with both top and bottom trays open. I noticed the white pegs and skinny black roller inside were turning when I turned it on, so I waited til they were spinning and slid the paper between them along the right side. (Kind of a reverse feed). Had to do it between the crazy ink returns. Yes, the paper crumpled a little, and I did it a couple of times with a couple of papers. Something gave, because after that it started feeding properly again!
Oct 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Paper d,ont feed unblock paper but no paper stuck
Good Luck!!!!!!!
Sep 25, 2011 | Lexmark X5495 Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
My printer is feeding more than one page at a time my printer is cannon 3000
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results?
May 23, 2009 | Office Equipment & Supplies
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Canon PIXMA iP1700 InkJet Photo Printer Logo
317 people viewed this question
old marine
old marine
Corne Viljoen
