Question about Sony VAIO PCV-W500GN1 PC Desktop
Sony Vaio PCV-W500GN1 shuts down moments after startup
When the machine starts up, it shuts itself off. I does not log off, it just goes black. It will not startup again until it gets unplugged and plugged back in. It will sometimes shut down before Windows even starts up. I replaced the cord thinking it might be that simple, but it keeps shutting down. My first thought is that it is a power supply problem. I have noticed on this site that this seems to be a common problem for this machine. Any help?
  • David May 11, 2010
    Hi Patrick,
    You might want to try a couple of troubleshooting steps first.
    Does the laptop perform this way when plugged into the mains. (I assume yes)
    Does the laptop perform this way when unplugged.
    Does the laptop get 'further into loading' when plugged into the mains.
    Remove the battery from the laptop. Leave the laptop turned off for 15 minutes. Plug the laptop into the mains, BUT leave the battery out. Does the laptop still turn off ?
    It may be that you have a faulty battery (it's not uncommon) and you may have to get a replacement. In which case if the laptop is under warranty, I would then suggest phoning up Sony technical support.
    I hope this helps!
    Problem Solver:
  • 18 Answers
Hi Patrick,
How did you get on with those tests ? Any joy ?
Posted on Nov 19, 2008
Try this website and download Important Notes During the installation of this file, be sure that you are logged in as the Administrator or as a user with Administrative rights. To ensure that no other program interferes with the installation, save all work and close all other programs. The Taskbar should be clear of applications before proceeding. It is highly recommended to print out these instructions as a reference during the installation process. or Download manual repair (Click here) for SONY PCV-W500GN1
All the Best!
Oct 02, 2010 | Sony VAIO PCV-W500GN1 PC Desktop
Computer just turnoff suddenly
Could be one of two most common problems?
Have you ever replaced the CPU Cooler (Heatsink/fan)?
CPU Cooler fan may be working, Heatsink dirty.
CPU is over-heating = mainboard turns off
Replace CPU Cooler
Power Supply fan not working causing partial failure on 5volt or 12volt side.
Replace Power Supply
There are more causes but these are most common for short-time boot problems.
Another could be hard-drive, but that wouldn't shut system down like first two would.
Apr 04, 2010 | Sony VAIO PCV-W500GN1 PC Desktop
Hard Disk Crash
If you have replaced HDD of your machine, then there is no otherway to get your things back rather than installing them. If you have CDs from Sony, then you are safe.
May 13, 2009 | Sony VAIO PCV-W500GN1 PC Desktop
Problem with Sony Vaio pcv-rx860 (screen goes black at startup)
I would suggest first to try to take one stick of memory out and try to boot up the pc. Sometimes, one or both of the memory sticks can go bad or the memory slot on the motherboard itself can go bad. If that is not the case I would then remove all of the usb connected to the computer and last i would test the power supply.
Apr 16, 2009 | Sony VAIO Digital Studio PCV-RX860 PC...
I have a sony desktop and the internet shuts down every 15 minute
only the internet or the pc
do a windows update and update internet explorer
are you getting any error messages when this happens
Jan 25, 2009 | Sony VAIO PCV-W500GN1 PC Desktop
Sony Vaio PCV-W500GN1 Shutting down
When was the last time you cleaned your computer? Overheating from dust accumulation can cause this kind of problem.
Check to make sure no dust has accumulated in the vents. You may need to carefully open up your computer, and use a can of air to clean out dust on the components. Be aware static electricity can destroy pats of your computer. Make sure you ground yourself by touching a piece of metal before opening the computer case. You don't need to touch anything in there, however. Just carefully use the canned air to clean things out.
Good luck.
Dec 30, 2008 | Sony VAIO PCV-W500GN1 PC Desktop
Sony VAIO PCV-W500GN1 PC Desktop Logo
491 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
