Question about HP Photosmart MZ67 Digital Camera
My lens on my kodak easyshare m580 digital camera is stuck open and as extended as it could be. i've dropped it and that's what made it do this. i cant turn my camera on or off but when it gets turned on the inside of the camera makes a rough noise and the lens wont go back inside.
    Top Expert:
  • HP Master
  • 63,391 Answers
Sadly dropping cameras is never a good thing . check with KODAK as to repair possabilities there may be none
Posted on Feb 15, 2018
SOURCE:
ImWireless
  • 113 Answers
SOURCE: Dirty lens
It would never be recommended to open the camera's lens on your own. That is exactly the reason why the repair shops are reluctant to open it. If you are having issues taking pictures due to the dirty lens and the camera is still under warranty, please talk to HP and they must be able to offer help on this. good luck
Posted on Mar 23, 2007
  • 3 Answers
SOURCE: HELP! dropped camera, lens won't go back in, shutter won't close
I have a camsung L830 that had similar problems and and after I would turn it on, it would beep three times and turn off....but I somehow fixed the lens by turning the camera on and then either pushing/pulling on the part the stickes out and hopefully it might activate the mechanism and it'll go in...that's what happened with mine...the shutters still won't close though. But I'm happy I can use my camera now.
Posted on Jul 26, 2008
SOURCE: kodak m763 wont stay on
i think you should take the battery out then hold the power button for ten seconds then put the fully charged battery back in if it doesnt work go back to the store and have them look it over.,
Posted on Oct 13, 2008
SOURCE: lens error M627-31
what can i do to solve this problem
m627-31
Posted on Apr 12, 2009
  • 54 Answers
SOURCE: Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Posted on Nov 24, 2009
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Nov 29, 2015 | Kodak Easyshare M580 Digital Camera
Kodak m1063 lens stuck closed won't open
I suggest you take your camera to a digital/Kodak camera repairer.
Apr 18, 2013 | Kodak EasyShare V1003 Digital Camera
Will not start
These models have recurring problems, needs service/repairs.
Nov 11, 2012 | Kodak Easyshare M580 Digital Camera
My Kodak Easyshare M580 works but the shutter will not go in all the way when turned off? Starts to go in then stops.
The problem is in the shutter itself, I would use it until it go's completely, it would cost as much if not more to have it repaired, chances are they would replace the whole lens housing.
Mar 13, 2012 | Kodak Easyshare M580 Digital Camera
My Kodak Easyshare camera is showing Lens error 111. Can this be fixed without sending for repair?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 30, 2011 | Kodak Easyshare C813 Digital Camera
How do i date stamp photos i take on my kodak easyshare m580 camera???
I've checked in the manual and I don't think this camera has a date stamp feature on it. Other than that you can put the date on the image on your computer using a photo editing program like Photoshop. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Kodak Easyshare M580 Digital Camera
Hi, My Kodak EasyShare C613 intermittently starts up ok, but other times the lens extends and the viewfinder stays on the initial screen. (The Kodak EasyShare system 'share') After around 40 seconds...
My camera is stuck on the screen that says "lens error" and then has four different numbers in a row. The camera lens is fully extended and will not shut off...any suggestions of what the problem could be?
Nov 04, 2010 | Kodak EasyShare C613 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
HP Photosmart MZ67 Digital Camera Logo
103 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
