Question about Sanyo DS27820 27" TV
Motorboat sound I have a 25 in sanyo tv. when i turn the tv on it makes this motorboat sound behind the power button. Can you please help me on fixing this problem. thank you
    Genius:
  • 1,074 Answers
Problem in the power supply a filter cap is bad check the repairman to locate the bad cap good luck.
Posted on Apr 11, 2007
SOURCE:
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Sanyo 25" 10yr old model
is the sound like hissing or like a spark something like?hissing can caused by leaking of high voltage that is dangerous and sould be fix right away
Jul 13, 2011 | Sanyo DS25390 TV
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
MY LCD TV SANYO 32"
Possible that the power supply has failed . you must open the rear panel to look into the power section only if you are capable to handle power electronics.
Please find the link below for help:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Nov 01, 2010 | Sanyo Televison & Video
SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Sep 21, 2009 | Sanyo DP26647 26 in. LCD TV
Have a Sanyo tv model DS31520. Won't turn on. push power button, nothing. checked fuse on board-o.k. Power to circuit board. Any ideas what to check next?
Sounds like the switch is missing the mark behind it. Take the back cover off and see if the back of the push ON switch has been worked loose from pressing.
Hope this helps bud.
Jul 24, 2009 | Sanyo Televison & Video
Sanyo ds-25350 TV won't turn on, just clicks twice
Sanyo ds-25350 ? Not recognising that model number.
Sep 16, 2017 | Televison & Video
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
No power
It sounds like you have a problem in the set's power supply or high voltage section and the set is protecting itself from turning on. Unfortunately, you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 14, 2008 | Sanyo HT32744 32" TV
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
Sanyo DS27820 27" TV Logo
73 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
