Question about Dishwashers
Dishwaser working,but not cleaning dishes properly
Ive tried different tablets,dishwasher has been cleaned for lime scale, filters and spray arms are clean , ive checked all hoses,tried longer wash program. it was working well 2 weekc ago but now isnt doing the dishes properly. its 18 months old. i think its not spraying properly? can i operate it and watch whats happening?
  • akubra_lands Nov 18, 2008
    thanks joe. i have been running water hot in sink before i start dishwasher. it was working fine but now its not. i think its the spray arms and will listen out for the water on the door and see how i go. light steam comes out when finished.if spray arms ok is it possible that the dishwasher is not heating water properly?there used to be alot of steam,really hot! is there a heater element that may have gone and temp now is only from hot water?
  • Anonymous Mar 27, 2014
    The spray blades etc are coated in black scale
  • 21 Answers
Make sure the top rack sprayer bar at the back of the dishwasher is not slight bent and entering the hole. If the top rack adjusts height, sometimes it can be bumped out of alignment when you adjust. You can put it in the guide, and it will go in the hole (with rubber cap) in the back of the dishwasher when you push in the top rack. You can pop out the spray arms and make sure they are not blocked.
Finally you might have a build up of deposits on the screen. You can remove and clean. As it won't recycle water adequately. I don't work for Lemi Shine, but their machine cleaner made my dishwasher run like new.
Posted on May 23, 2014
  • 41 Answers
Unfortunately, there is no way to run it and see what it is doing. the only way to check if the spray arms are working properly is to put your ear up to the dishwasher while it is running. you should hear the water spraying along the door panel on both the top and bottom ( Note: some dishwashers run the spray arms simultaneously and sometimes they run at seperate times ).
another thing to check is your water temperature. the water must be 120 degrees in the dishwasher in order to clean the dishes properly. also, if your kitchen sink takes a while to get hot water, you will need to run the sink first prior to starting the dishwasher. I have to apply this method at my house because it takes a while for the water to get hot at my sink. if I run it without starting the sink, the water in the dishwasher is 80 degrees or so and will not clean properly. Joe
Posted on Nov 18, 2008
  • rbnsn6 Nov 18, 2008
    the heating element is not meant to heat the water. it is for drying purposes. the only way to check if the heater is working or not ( other than touching the element after a dry cycle to see if it is hot ) is to check it with an ohm meter on tone. if you get tone, then the element is good. Joe
The tablet is still in the dishwasher when the cycle is done the tablet door is open and there's nothing blocking it but the tablet is only half used thanking you? Maisie
If you have used the same tablets before with no problem I'd say not enough spray or not enough spray pressure now. Clear all holes in both spray arms and clean the filter or filters. If you are trying a new kind of tablet try a different one or a powder. If it is still getting your dishes clean be thankful and don't worry.
Jan 24, 2017 | Dishwashers
Whirlpool dishwasher model GU2275XTVQ1 cleans poorly on top only
Check your hose, pump and all water lines for lime scale build up. Sometimes if you dont use some kind of lime away product every few months your machine will/can get lime scale build up from hard water causing it to not properly dispense the water through out your machine. You can also try to run a load with no dishes and no soap but put just lime away in your machine. It might just clear any clogs you might have or starting to get.
Jan 27, 2013 | Whirlpool Gold GU2275XTVy Dishwasher
I have a ge quiet power 3 dishwaser and its leaving a whit residue all over my dishes. Ive tryed new detergent jet dry and even cleaned the area where the detergent goes into but nothing has worked
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 03, 2011 | Dishwashers
My dishwasher has not been cleaning well over the last few months. Ive tried different dewtergents but it seems more to do with the operation. How do I figure out whats going on?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 17, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Model gu1200xtlq dishwasher can't find my manual it is 8 years old and having problems with dishes not getting clean particles left inside cups and on dishes and even inside the tub after a cycle
you can go to www.frigidaire.com and input your model number in the manuels colum and you will be able to download a new manuel.
to clean you dishwasher you can use some CLR or any other kind of lime and scale remover to clean the inside and the spray arms.
if this does no good then you may need to replace the main wash motor.make sure there is enough water in the unit when it is running lack of water is a big problem with not getting dishes clean
Jul 05, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher not cleaning dishes properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
zzty
Jun 16, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Gritty Dishes
The only thing that can cause grit in the dishwasher is something you put in it or it's not rinsing as it should. As you use tablets we can probably rule that out. If you don't have hard water we can rule that out too.. So next up is not rinsing properly. The spray arm in the bottom of the unit has little holes in it. Many times junk that gets by the filter end up in these holes. When that happens the water will not spray out correctly, your dishes don't get properly cleaned and rinsed. Pull out the bottom rack, you might need a flashlight but you need to look at each hole in each arm and see if they are clogged. Even if you don't physically see anything remove the spray arm and clean it, sometimes stuff will fall back into the arm when there is no more water trying to flow. It is very easy to remove. Anyway, remove the spray arm, pick out anything you see stuck in the holes, run water back thru the holes in your sink and re-install the spray arm.. Hopefully this is your problem. Here is a video (it's not mine) which shows how to remove the spray arm.. good luck !
https://www.youtube.com/watch?v=KZWGrb8ZV3E
Jan 23, 2018 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher runs but the dishes aren't clean and low water pressure out of the arms dish soap left in the dishsoap tray
Try some Lime Away or high strength vinegar, to remove any scale from the pump. If it is not scalely, try to remove the spray arms to check if the pump has trash in it.
Sep 19, 2009 | Dishwashers
Clogged water dispenser in Bosch dishwasher
Hi, Logmanup (slight bouts with dyslexia, sorry)
By "spinning water dispensers", I assume you mean the spray arms, right? OK... if they are getting clogged with debris it would be nice to know what kind of debris. Pieces of broken glass? Plastic? Lime scale? Iron? And yes, when they get clogged they won't rotate, won't allow pressurized water through and therefore won't clean the dishes.
For the purpose of this solution, I'll assume that there are little white particles clogging up the jets on the spray arms. This indicates hard water and lime scale build up.
Other than completely disassembling the entire motor/pump assy. (you really don't want to go there), the best way to clear this out of the system is to use an over the counter chemical called Dishwasher Magic or something similar. If the lime scale build up is really bad (and it sounds like it is), use a couple of bottles to start with and follow up with a bottle per month thereafter.
As an aside... If I assumed correctly about the lime scale build up, that means that it's also affecting other appliances as well. Mainly, your hot water heater. If you haven't done it before, please read this to perform maintenance on it. And a product something like this for your washing machine.
I hope this was helpful. Let us know if this works or not. If not, please write back and we'll go a little deeper.
Mar 12, 2009 | Bosch Dishwashers
Fine gritty residue on dishes, particularly on glasses
alm84, Are you using a brand name powder like Electrosol or Cascade? Try that first. Seriously, it makes a difference.
When you say your water temp is within the recommended temp for the detergent manufacturer, do you mean the water heater temp at the sink tap is 120 degrees? MOST problems with cleaning that are not caused by generic detergent or plugged filter/debris in the impeller area are caused by a failed heating element. No kidding, it makes a BIG difference and once it is repaired, you will see an immediate difference.
glenda, First try this: remove the lower spray arm and the filter and assembly. Clean everything in the sink and with a flashlight, inspect everywhere for "chunks" that is probably causing the noise.
Reassemble and test. If dishes still do not get clean, check the heating element, replace if needed.
If that does not fix the problem, you will need to replace the main wash motor/impeller.
Good Luck!
Please update me with what you both find. OK?
Feb 25, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
283 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
