My PC stopped displaying video. I've changed the motherboard with new processor, including new video card and new memories. Power supply runs well. Could this be a computer box proble? It switches on and off. All components run smootly except video display.
    Problem Solver:
  • 9 Answers
This could be a software problem?
Posted on Nov 18, 2008
Can i run new ati radeon 512mb video memory with 5.0 shader card on acer ACER AST690-U-P925A
1) How much Ram Memory do you have installed? If I have the spec's right, your motherboard's maximum amount of Ram Memory is 2GB.
(PC2-5300 would be best, but the amount is what matters, not the 'speed')
2) What is the Maximum Wattage for your Power Supply?
Takes power for each hardware component in the computer.
Motherboard, Processor, Ram Memory, Harddrive, Optical Drive/s, Graphics Card, etc.
When purchasing a graphics card, this is one of the minimum system requirements you need to know.
Spec's I looked up indicate a 300 Watt power supply.
This is the problem. That, and power supply's Acer uses are low quality.
If you had at least a 400 Watt power supply, you could use this,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=41125&Sku=E145-0550
Slap that game around, and make it bark.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483
You could also run this if you had the above Power Supply,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2048679&Sku=M452-7770
[Note*
No. It does not matter if you are using DDR2 Sdram ram memory, and the graphics card has GDDR5 graphics memory.
A graphics card runs independent of the system resources.
(Processor and Ram Memory ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 24, 2012 | Acer Aspire T690 (AST690UP820A) PC...
My PC is not starting what is problem.
first make sure your ac cable is working well, then try to check the power supply of your computer if the fan rotates every time you hit the power button of your cpu, if not then change your power supply. if it fan rotates and stops, try to used another power supply if fan rotates and still won't display open up your cpu try to check if the fan over the processor will rotate and still don't recieve display. try to remove the video card and memory and clean it and re insert it. if still don't work. you got your motherboard defective.
Jul 10, 2011 | Intel SRMK2 Motherboard
Acer veriton m460 won't turn on fan runs that's it
Power supply failure. Replace it. Get 50+ more watts than the original. Power supplies are inexpensive and can be replaced without affecting your operating system or programs.
BTW: Many "failed" power supplies still can deliver enough power to spin fans and turn on the lights.
I recommend: www.newegg.com
If this helps please vote for my solution.
Jan 25, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
Hi, when i power on it shows in brown color, (blink in brown) nothing dispalys, i changed ps, memory, processor. but didn work out
The only thing that's left is your motherboard. The usual culprit in a black out mode is the power supply and the motherboard. Try using a certified good motherboard. Try also to check on the display card. Also, check for compatibility of the power supply, the motherboard, the processor, display card and the memory
Sep 13, 2010 | Dell OptiPlex GX520 PC Desktop
Won't post, no beep. No display on monitor. Tried different AGP video card, different memory. I have unplugged everything but the AGP card and hard drive. The monitor works on a different computer so...
Basically, display card, RAM and processor are the ones affecting the display. IF trying different memory and video card doesnot help. Try changing the different processor. Thanx with regards Sajan
Jan 21, 2010 | Abit IC7-MAX3 Motherboard
Changed power supply, everything is connected and
well you may have a bad video card or maybe even a monitor have you tried another monitor? if so, then you can purchase graphics cards at most electronics stores!
Dec 22, 2009 | Gateway GT5012 PC Desktop
I have a HP media center m7360n , with a 920 intel pentium D processor. I changed the video card which required a more powerful power supply. I upgraded the ram and changed the power supply out to be...
Open your computer casing where the motherboard lies in and then remove the memory card, your new video card and then reset the BIOS, refer to the motherboard manual on how to do it. After resetting, plug in the memory card and video card. Close the casing and connect all the wiring. Power up your computer.
Nov 03, 2009 | HP Pavilion Media Center TV m7360n...
SuperMicro H8DCE-O R Motherboard no video
did you plug up toe power to the video card, the problem seems to be that the video card is getting no power, if the power is hooked up properly to the video card, the your power supply is probably not powerful enough.
Dec 04, 2008 | SuperMicro H8DCE-O R Motherboard
SuperMicro H8DCE-Motherboard no video
Are you hooking up The 24 pin ATX J1B1 connector and the 8 pin processor power connector JBW1 ? Alot of guys don't realize that new AMD's get power from a special connector on the motherboard..If you don't have this connector on your power supply you will need to get one that does. Hope it is this easy.
No display on screen and solid amber light on pcs' power button
Well hate to say it but that sort of problem results from a faulty motherboard or processor so if you say that you have changed the motherboard then you problem lies with you processor chip.
Jun 06, 2008 | Intel D865GBF Motherboard
Computers & Internet Logo
David Payne
David Payne
