Question about Sewing Machines
White 804 Sewing Machine Lubrication
Hi, can you identify the correct oiling locations for this machine? TIA
  • Sewing Sue W Nov 19, 2008
    Hi, Thanks for the comment. There are a number of holes in the machine's top cover, are they all oiling holes?
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Janome SD-2014 sewing machine dogs fails to operate in reverse
The grease has hardened and that is what makes it not work. You need to remove the spring and clean all the old grease off it. You can put new grease on if you want but it isn't necessary. The machine should be lubricated with a good quality sewing machine oil(not 3 in 1). You need to oil any place that moves and rubs, This includes the ends of each shaft, the needle bar and the cinnecting links that drive the needle bar. Nothing is permanently lubricated.. you'll find this machine will run much smoother and quieter with fresh lubrication.As a matter of fact, if you use the machine a lot, it should be lubricated once a year and never less thanonce every 5 years.
One more thing. If it is on the main shaft that it has hardened you can spray it with a mixture of fantastic, water and some ammonia. Free it up and give it a light shot of oil.
sewman7
Posted on May 02, 2009
Mimito7
  • 128 Answers
SOURCE: Need Oiling Locations for Sewing Machine
Hi there.. Looking at your machine from the top, there should be an opening near the bobbin winder, then there should be others located near the top left of the machine, and on the base to the right of the feed dog. you can also put a couple of drops on the feed dog, take out the bobbin and put a couple of drops on the moving parts and run it with out a needle or thread to get the oil in to where it needs to go.
Posted on May 21, 2009
Mimito7
  • 128 Answers
SOURCE: need manual for it WHITE SM2000 Millennium Edition sewing machine
try this::
www.2instructions.com
Posted on May 29, 2009
rochelle0099
  • 5 Answers
SOURCE: I need a users manual for a White Sewing Machine -
I solved this problem by going to a post on FixYa dated 6/4/08 oor 09 by Timetoknit.
The post mentioned a free download of "White's" Manual that is out of print, at White's sister company "the Singer Sewing Company's" website: www.singerco.com It also gave the download steps. The download steps are on my Solution post.
I downloaded the manual and printed it on 7/30/09.
Thanks for being here.
Posted on Aug 02, 2009
I broke a needle and now my timing is out on my Bernina Artista 170. The hook is nearly a 1/4 inch in front of the needle when the needle is at its lowest point. Please tell me how to fix this. TIA
Turn balance wheel slowly until needle has risen about 3/16" from lowest point. Move hook back until immediately behind needle and just above needle eye
Feb 13, 2014 | Bernina Sewing Machines
I need a MANUAL for a singer made in 1949.
Hi Milton:
First you need to identify the model of the machine. Here is a link to a visual guide to do that.
http://www.sandman-collectibles.com/id-singer-machines.htm
Once you have identified it.... Go here for the instruction manual.
http://www.parts.singerco.com/IPinstManuals/
Parts charts are here... maybe it will have or model
http://www.parts.singerco.com/IPpartCharts/
I recommend taping a large zip lock to the inside of the cabinet and keeping a copy of the manual and parts chart in there.
Have fun bringing the old girl to life...be sure to clean her up really well and give her a good oiling with quality oil. It's also a good idea to take apart the motor and make sure the armature is clean... and clear and grease the ports on either end when you put it back together. Use caution doing this because there are shims that must be put back in the same place.
Good luck
Sep 16, 2012 | Singer Sewing Machines
Hi dear expert I have a Husqvarna SM 125 '07 (zCGH200AB7V011268) I have such a problem: blinking light oil (3 long 3 short) oil in the tank is full, look forward to your reply, Regards Nazar...
That warning is for the oil pressure- it's missing. Check the pipe connecting the tank to the oil pump and the cartridge filter. If they are free then the pump and the engine will have to be dismantled to identify what went wrong.
Sep 22, 2011 | Husqvarna Designer I
Cant raise bobbin thread and needle is clunking
Is the needle in the right way? Flat shank to the back. Also the clunking could be a blunt or bent needle, change it, clean, oil and rethread everything.
Check that the bobbin is in and rotating in the correct direction.
Then test again very slowly, if problem still exists you need to identify where the noise is coming from during the stitch formation.
If the needle is striking part of the bobbin race during stitch formation, then timing is out and needs a serviceman.
Feb 26, 2011 | Singer Inspiration 4228 Mechanical Sewing...
How to oil old featherweight
Hi! I love the old Singer sewing machines!! Do you have the user's manual for your machine? The manual has great diagrams showing where to put oil and grease. If you don't, check out http://www.221parts.com/
In the meantime, look for little holes, often with raised edges and put a drop of oil in each. Put a drop of oil wherever metal moves against metal. You'll need to oil inside the head, on the right-hand side where the motor is located (DON'T oil the motor--use grease instead), and also underneath.
Good luck and let me know how it goes.
Dec 15, 2009 | White Sewing 1300DE Sewing Machine
May 21, 2009 | Sewing Machines
Futura ce200 software - LOST!!
Hi, software is available to purchase from the following website http://shop.jennys-sewing-studio.com hope this helps you out.
Steph
May 15, 2009 | Singer CE-200 Quantum Futura Computerized...
Problem with 40 old Elna Zigzag , V/NV/21, Type: 21cF347986
Um, sounds like the machine has seized from old, dry oil and it is dragging down the motor. Avoid using the machine until the issue is resolved so the motor is not damaged.
Depends what kind of oil & grease your husband used, as it could have complicated matters. Also, if the machine has been neglected for a long time, combining heat in the clean-up/lube process is sometimes very helpful. (Can't tell you the machines I've picked up that have had motor oil and grease applied!!! The old gunk needs to be cleaned out and then the appropriate lube applied.) Most machines do not use grease unless it is white lithium grease--perhaps on cams. Oil needs to be fresh, good quality sewing machine oil. I prefer liquid Tri-Flow Synthetic Lube from the hardware store. Do NOT use WD-40, 3-in-1, cooking oil, motor oil, etc. on your machine!
Wheel on right side that controls the needle up and down is very tight...
Mar 23, 2017 | Sewing Machines
Trying to locate a particular husqvarna sewing machine
This is a picture of my mum's machine from the 70's, which I still use regularly, the Husqvarna 3310.
The interesting feature was is doesn't need oiling. It's been a brillliant machine with no problems (until one I have at the moment). Good Luck.
Feb 02, 2008 | Sewing Machines
Janome Overlocker
Is it a three or four thread machine?
A three thread has little strength used as a seam.
On a four thread,basically, it is a tension problem. You need to ensure that the presser foot is in the up position before threading. The correct path is followed for all threads. You are using good quality thread. Reset the dials to 'normal tension' #3 or 4 .... then slowly work your way from there. The manual should offer advice on which tension to adjust to correct a particular problem.
Oct 08, 2007 | Singer 5160 Mechanical Sewing Machine
Sewing Machines Logo
123 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
