Question about Olevia LT32HVM 32 in. LCD Television
Olevia - heard loud snap/pop and Ant input not working right and Power up probs
I saw that you responded to another person that appears to have the same problem that I'm having wiht my TV. I would like to know if the you could read thru my issues and let me know what you think the solution is.
First, after having the TV for about a year I moved it across the room and was going to plug the Cable Cord into the Ant input on the TV - as soon as I did there was a huge SNAP/POP a blue flash and since then I cannot get the Ant connection to work. I can turn on the TV, select the source to Tuner but it tells me there are no channels in the list and if I try to add or search them it either by auto set up or manual it just doesn't find them I gave up on it and have been using the composite connection for my cable.(about a year now)
Second issue is that yesterday I was going to connect to the TV via the VGA cable - Same thing happened - huge SNAP/POP but now the TV doesn't seem to have a picture or problems powering on or something. I've got the blue light on when the TV is off - when I turn on the power it appears as if it's going to work just fine but then the screen stays dark and never lights up to the Olevia opening screen etc...If the TV is on I can't see anything, I can try to change the video input source but it doesn't do anything - also nothing will display if I try to get pull up the TV system setup - Basically the TV is on but the screen is black.
any help you could offer me would be fantastic! Just figures that this would happen 1 because I'm unemployed (stupid downsizing) and am freaking about cost to fix and 2 because I'm unemployed and home all day now with no TV.
Thanks so much
I just asked a question. You sain the answer has been posted. Where?????
Click on your highlighted name, I saw several posts. The bottom one appeared to have an answer. I don't know if it was the answer you wanted? I'm not a computer person, I doubt I can help.
If you want to reply to a post, click on the comment link, That way the person your talking to will know your asking another question.
Dec 15, 2016 | Cars & Trucks
How many babys can a person have?
The number is believed to be 35. Although the record stands at 69 but it is a dubious record because it dates back to the 1600's
Jun 21, 2014 | Computers & Internet
Hi I have a 6 person spa and don't know the brand
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Sep 05, 2012 | Cars & Trucks
Hi i have a samsung 40" LCD TV wiht the clicking
Useally it 3 more,it alway on the tv power supply board.The the board,where the power a/c plug into it.Seaches the entire power supply board for dying capacitors,it alway bulges up or puffing up on it tops.By replacing all these capacitors with the same Micro Ferit and about 10 voltage rating higher for those dead capacitors for better tolorance next power supply board spike heat waves.
Jan 27, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
In Fixya , There huge products and also Questions and answers. I really wonder that these questions and answers correspond appropriately??For example there are many Chain Saws . I wan to know each chain...
Hi wkojiro, welcome to FixYa. Questions on FixYa are usually categorized under the specific model of product that they are about. However, should that product not be on our site, the asker can make it "generic" for the category. When an Expert responds to that generic question, he can add a specific model categorization (if the asker overlooked it and it's actually on the site). If you have any other questions, you can always email Fixya Support Team at: support@fixya.com or use our contact page: http://www.fixya.com/contact
Sep 08, 2010 | FixYa Service
I have problem wiht my xbox 360 controler
If you are using an hdmi cable make sure it is fully pushed into the tv and console, if this is not the case comment with a bit more info, wireless or wired new or old controller, intermittent or constant fault, we may be able to help you more.
Feb 05, 2010 | Microsoft Xbox 360 Console
Need code for programming rca tv wiht a sony
find the correct code automatically.Turn on your device.
while pressing SET botton press POWER, and release them ,then press CH+,then release it
Then press POWER repeatedly untill your device responds.don't go too fast.
When it responds press ENTER to store the code.
Oct 14, 2009 | Sony RM-V202 Remote Control
Black boxes on a few TV channels - connected to DIRECTV
Turn off closed-captioning. You'll find it's set for "text" right now, probably from hitting a button on the remote without realizing it. The set is blanking the screen for the text which doesn't show up. (In your case sometimes it does. You're the first person who's ever seen anything that I've responded to!) On channels and programs where captioning isn't being sent the box doesn't show up, so you don't know you have the trouble.
Apr 25, 2009 | Televison & Video
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Remote control has lost communication with LG 32LX1D 32 in
I have the same problem. If you unplug the tv for a while then plug it back in it will work again for a time.
Nov 04, 2006 | LG 32LX1D 32 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
121 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
