Question about Radio Shack Pro-94 Scanner
No Response When i turn on the scanner I see some words but not readable, maybe LOCKED? But, even when cleared the only button that works is the light button.
I'm embarrassed to even suggest this as a solution, but if you accidently plug the AC adapter into the earphone jack instead of the power input jack, the display will show nonsense and the buttons won't work (not that I've ever done this myself).
Posted on May 09, 2007
Says "locked' an unable to use, no buttons work
The child lock is on. Turn off the lock by pressing and holding 0 until the word Locked disappears.
To turn on the lock, press Stop/Clear and then press and hold 0 until the phrase appears.
The manual for the Jenn-Air JMC8130DD is available from http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC813&siteCd=JA_EN_US&userType=Consumer .
I hope this helps.
Feb 02, 2011 | Jenn-Air JMC8130DD Microwave Oven
My Radioshack Pro-82 Scanner is stuck. I turned it on, held down the "lock" button until the keypad locked. The screen didn't display the "locked" symbol, but I can't use the keypad either. Even if I try...
First reset the scanner. This will not remove frequencies from memory. Turn the scanner off and then on again. Use a straightened our paper clip to gently push the "Reset" button on the side of the case (small hole). If that doesn't work, the next thing to do is to reinitilize the radio. This blows everything away so its the last resort. If you have the cable adapter and CD ROM for the radio, you may still be able to back up the scanner and reload after you do this. If not, be prepared to reprogram.
Turn the radio off and back on again. Hold down the "Tune/Clear button and again push the reset button. The display should clear. When the display returns, release the "Tune/Clear button
Now reprogram.
Aug 16, 2010 | Radio Shack Pro-82 Scanner
I have a Pro-95 scanner that I enjoy alot, the problem is that the keypad seems to be locked, sound and squelch work fine but not a single button, I've tried the reset button several times. Any help would...
Look at the keyboard and find the button the shows the symbol for a key and a symbol for a light bulb. Press the FUNC button and then the key indicated above. The words key unlocked should appear in the display. Repeat the process to lock the keys again.
Jul 11, 2010 | Radio Shack Pro-95 Handheld Scanner
All Channles locked out
To clear all locked out channels, press the SRCH button, select the bank you want to clear, press the FUNC button, then press the L/OUT button, then press FUNC button,then 6, press 1 to clear all...hope this was helpful...
May 20, 2010 | Radio Shack Pro-97 Handheld Scanner
Scanner locked?
On some models there is a transport latch to lock the scanner. Look under the scanner (where the copy comes out) and you will see a green slide. Look down thgrough the scanner glass and you will see a lock/unlock symbol.
May 05, 2009 | Brother IntelliFAX 4100 Laser Fax
Can't get audio on Bearcat 244CLT scanner, or get any of the buttons to operate properly. Can set the clock, but that's it. Volume and Squelch set all the way to right, not even static sound. Nothing on...
You can try a master reset. This will delete any frequencies that are programmed. Here is the way to do a reset...
Turn scanner off. Hold down, 2-9-HOLD (all three keys at once)while turning on the scanner. Keep holding the keys down for about 3 seconds. The word CLEAr should come up on the screen.
Apr 03, 2009 | Uniden Radio Communications
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
Mar 28, 2009 | Magic Chef MCM660A Microwave Oven
Samsung "scanner locked"
I went through the same thing! It drove me nuts, and I even calls CS, which is great by the way. The sweet girl on the other line couldn't figure it out, but I finally Googled it.
In the opening where the printed pages come out, if you put your hand in there, on the top left is a lever.
This is the scanner lock. Once you flip the lever and hit the stop/clear button, it should be all better. At least that is what worked for me!
Nov 06, 2008 | Samsung CLX 3160fn All-In-One Printer
Failure to open OCR documents scanned into Microsoft Word in a readable format
Have you installed OmniPage? What OS are you using? Which scanner did you have previously? Are you able to OCR a document through OmniPage?
Jul 26, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Radio Shack Pro-94 Scanner Logo
67 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
