Best Solution
posted on Dec 24, 2006
All you need to do is a manual code search on the dish remote. If it does not respond with the manual code search,the remote your trying to use cannot be used for this TV set,or you will need to upgrade to a differant Dish remote as the code is not programmed into the remote. What happens when you do a manual code search is one by one the remote sends out every single code that is programmed into the remote. Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for iLO -2600 Television
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Repair Service
Find Flat Panel TV Repairman Near You:
