Question about Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH5500BWW Fails to spin properly clothes wet
Hello:
I have a MAYTAG MAH5500BWW SN A2946479CA front load washer.  The machine leaves the clothes wet and in fact does not spin and complete this cycle.  I had an honest repairman come out and 3 hrs later still can't find the problem.  This is was tried:
Symptoms:  The clothes are wet with visible water in the tub.  When the spin cycle starts it at times will spin slowly then stop then start again.  During this time pump may come on intermitently.  Spin can get some RPMs with no load but will go through a cycle of low to high RPMS multiple times.  The count down time may also jump back up such as from 2 minutes back to 7 minutes.
1.  Verified the water is being pumped out.  Pump is working fine.  Checked to ensure no lint is stuck in pump.
2.  Did a continuity test on the 3 sensors.  All 3 switches working okay.  Tried to short 3 sensors as well to take them out of the loop.
3.  Motor does work and will go up in spin speed at times.  The problem with spinning is that it goes up in speed then drops down then up then down.  Sometimes it goes higher than others.
4.  Tried to bypass out of balance sensors by jumpering red and orange leads together on control board.  No effect.
5.  Repair person called MAYTAG for help and ran all diagnostics.  Everything comes out ok from a diagnostic level.
Is there any detailed outline of how to bypass each sensor or a group of sensors?  Maytag said the machine might be out of balance and to just run a full heavy load through.  This didn't help.
Thank you for your help
ihave the same machine and problem ,tried to do a spin test and the display only showed "00" and would not spin very fast. it would stop and start repeatedly but get up to the proper speed
  • dabawr1 Nov 22, 2008
    i didnt get the answer to my question from hermajai
    why doesnt the display show the spin speed doring the quick spin test
  • 367 Answers
Have you replaced the motor control unit. This is what sends the signal to the motor.
Posted on Nov 22, 2008
    Genius:
  • 1,239 Answers
HI SIR YOU SAID IT IS RUNNING SLOWLY AT START UP SO THIS IS THE CHECK YOU HAVE TO DO NOW test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
  • ABHISHEK.C
    ABHISHEK.C Nov 22, 2008
    The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
    If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced
  • ABHISHEK.C
    Of all washing machine parts, the water pump probably takes the most punishment, because it is constantly in use. When the pump fails, you can hear or see the trouble: a loud rumbling inside the machine, or a failure of the water to drain out of the tub. Here's what you can do to fix the problem:
    Step 1: Check the drain hoses to make sure they are draining properly. Remove the water supply hoses from the back of the washer. With long-nosed pliers, extract the filter screens from the valve ports in the washer or from the hoses themselves. Wash the screens thoroughly. Then replace them and reattach the hoses. If the machine still rumbles or doesn't drain, examine the pump.
    Step 2: To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the bottom of the machine, but with the unit tipped on its front it's easier to remove the pump through the back than through the bottom of the washer.
    Step 3: Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Then try the machine again to see if this kinking was causing the problem. If the machine still doesn't drain, you'll have to remove the water pump.
    Step 4: To remove the pump, loosen the bolt that holds the drive belt taut and move the washer motor on the bracket to loosen the belt. Move the motor out of the way and unbolt the pump; it's usually held by two or three hex-head bolts located on the bottom of the pump housing. As you loosen the last mounting bolt, support the pump with your hand. Then lift the pump out of the washer.
    Step 5: You should take the pump apart if you can, because the trouble could be lint, dirt, or pieces of cloth or paper clogging the pump impeller. Clean away all debris inside the pump and clear any debris out of the water tubes. Then reassemble the pump. Hook up the pump again and test it. If cleaning the pump doesn't put it back into working order, or if the pump housing can't be removed, replace the pump with a new one of the same kind.
    Step 6: To install the new pump, set it into position and connect the mounting bolts to the pump housing. Move the motor back into position. Tighten the drive belt on the motor by prying it taut with a hammer handle or pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
    Step 7: Reconnect the hoses leading to the pump.
  • Maytag Master
  • 19,396 Answers
Tell the repairman to check that the water is being heated properly, and that the thermistor is fine.
If the water does not reach temperature because the element is defective, or the thermistor is faulty, then you ge the cycle not completing.
Tell the repairman to check also the Motor Control Unit, that is an electronic sealed box connected to the motor.
  • Ginko
    Ginko Nov 22, 2008
    Great , you refused the solution, I think you wont be able to see my comments from now on.
    If the display show the spin speed doring the quick spin test, then probably you have a faulty control assembly, ask the technician to replace it, now enjoy all the help from the great engineers we have on Fixya.
    Goodbye.
    Scholar:
  • 181 Answers
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Posted on Nov 18, 2008
  • 4,806 Answers
The belt that drives the drum may have either snapped or stretched, you can check this from the back of the machine, if the belt is still there and is tight then its programme or sensor error
hope this is of help and good luck
  • Lee Hodgson
    Lee Hodgson Nov 22, 2008
    this could also be the balance and weight sensor which has become defective, the machine will wash but will not spin. I had a similar problem with my machine and after a while i found that it was the drum bearings which was causing the problem, this maybe the case with yours.
    consult your user manual about correcting the problem.
    regards
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
I replaced the motor and circuit board but that did not fix it. I changed the out of balance switch and the shock absorbers or snubbers. I think the ultamate fix was the snubbers. it has worked great since. They wear out like your car shock absorbers allowing the drum to shake too much triggering the out of balance switch to stop and restart the spin.
Oct 22, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
