Auto Align problem
I'm trying to use the Auto align feature on my Roland printer to automatically read the crop marks on a print & cut job. The printer will read the first 3 crop marks, then it will get a little more than half way to the last crop mark and give me an error message "Cropmark Error - Not Found" I've tried this on several different jobs and many times and on every job it seems to stop and give me the error message at the exact same spot... Any suggestions?
El Duderino
  • 47 Answers
SOURCE: Flashing Lights on HP 690C - Won't Print
Hi Stev, First I know this is going to sound strange but have you disconnected the printer cable from the printer itself? (not the computer) If not try unplugging both the parallel and power cables for 30 seconds, then when you reconnect and power up hit the resume button. I've seen problems in the past where a job was killed like that and the printer would not work until the parallel cable was removed from the printer. The light pattern you describe, resume light blinking with the power light on, can mean any one of the following things on that model HP. 1. Top cover is open. Open the top and make sure there is nothing keeping the cover from closing all the way. Don't forget to check the underside of the cover for something stuck to it. Close the top cover. 2. A print cartridge is missing or an incorrect print cartridge is installed. Install the correct print cartridge. AND/OR Verify that the print cartridge is properly snapped into place. Close the top cover. 3. Printer detects an out-of-media condition. Load media in the lower (IN) tray and press the Resume button. 4. Media is improperly loaded. Remove media from the IN tray, re-square the stack, and reload. Make sure that the media-width adjuster and media-length adjuster are against the stack of media. Make sure that media is not buckled in the IN tray. Verify that the media-width adjuster is along the left edge of the tray and is pushing the right edge of the media against the right wall. 5. The printer timed out waiting for a form-feed command. Press the Resume button. The page will eject from the upper (OUT) tray. 6. Printer detects out-of-ink condition. Replace the print cartridge and press the Resume button. 7. Dirty Cartridge Contacts Use a clean foam-rubber swab or lint-free cloth slightly dampened with water. (Distilled water is recommended. Tap water might contain contaminates that could damage the cartridge.) Locate the copper-colored circuitry strip on the back of the cartridge. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. Unplug the power cord from the printer. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or lint-free cloth to remove the moisture from the contacts. If the carriage contacts show noticeable damage, contact the HP Customer Support Center listed in the printer's User's Guide. Plug the printer back in and try printing again. 8. Printer detects paper in the paper path. Turn the printer off and open the top cover. Make sure that paper is not jammed in the printer. Lift the right black rectangular paper sensor (located in the middle of the printer just below the silver rod on which the cartridge carriage slides) and make sure that nothing is stuck under the paper sensor, perhaps by blowing under the sensor. Close the top cover and turn the printer on. Try printing again. If none of this helps let me know and I'll see what else I can dig up on the problem. El Duderino
Posted on Nov 17, 2006
Tonerman
  • 62 Answers
SOURCE: alignment cartridge
this is an internal problem in the printer, there is a transparent tape in the printer and it needs cleaning or replaced
Posted on Jun 10, 2007
SOURCE: Scanner Error Turn printer off & back on
i m italian my inglish is not good... i solve the problem clean the guide of the carrel of the light... so i can run more easy...
Posted on Nov 13, 2007
SOURCE: HP OfficeJet 6110 All-In-One
HP office jet 6110 all-in-one Printer will not print off internet, comes out gibberish.
Posted on Apr 05, 2008
SOURCE: Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Posted on Aug 19, 2008
While taking a print or photocopy shadow is coming on the center of the paper
My printer printing shadow behind all the letters
f you are running the printer's Full Feature Software, go into the Solution Center in the Toolbox and look for a way to clean the cartridges and / or print heads. Do it twice. It uses a bit of ink, but it will get any extra residue drifting around on the nozzles.Your printer's Webpage:
HP Photosmart C4795 All-in-One Printer
Look on the Menu (on the Printer) for the Alignment test. This may also be listed in the same area in the software section where you find the "clean cartridges" option.
General Instructions (may vary):
Align the print cartridges
The printer automatically aligns the print cartridges after a new print
You can also align the print cartridges at other times to ensure optimal
print quality.
To align print cartridges:
1. Load Letter or A4 plain, white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Print Cartridges.
4. Click Align, and then follow the onscreen instructions.
Jun 24, 2015 | Kyocera FS-1035MFP
HP ink jet 1200..prints only test page after replacing the yellow cartridge.test page only shows black and blue inks are good.need help.
Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
Dec 11, 2012 | HP Inkjet 1200dn Printer
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
It does not print black
Try Cleaning the Cartridges manually and automatically.
For the cartridge clean it with a damp lint free cloth and also for the printheads wher eyour gonna be inserting the cartridges.
Follow these steps do do the automatic aligning and cleaning:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
For Cleaning the Printheads, Instead of choosing Align Printer choose Clean Printheads.
I hope this helped.
Try Printing Again. I hope I was able to solve your problem. :)
Feb 14, 2011 | HP Photosmart C7280 Printer
My printer will not do color it comes out purple
I hope this helped.
Feb 13, 2011 | HP DeskJet 820Cse Printer
In hp officejet pro k5400 printer i can't get color print after giving any print...i've installed new ink cartridge also but still i can't get color print....
I hope this helped.
Feb 08, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
My print head doesn't seem to be able to align when I try the "print head align" feature that came with my printer. I've run a few iterations of the print head align feature and it doesn't ever seem to...
Most printers have an align command. Your printer manual will tell you how to use it. Failing that, try right clicking on the printer icon at the bottom taskbar to see if you can find it in the menus there.
May 12, 2010 | Epson Office Equipment & Supplies
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
Hp psc 2210 all-in-one printer is busy
I replaced the black ink cartridge and my printer keeps saying press enter to
align cartridges. I have done this a dozen times using up paper and ink and it
still says pres enter to align cartridges.
Jan 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
76 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
