Question about Pioneer DVR-530H-S DVD Player/HDD Recorder
DVDR-530H malfunction I have been using the recorder for several weeks successfully. Now when I insert a recordable disc, it immediately ejects the disc. I have also used it as a player for both discs I have recorded on the HDD and copied, as well as commercial discs so I know that the problem is not one of compatiblity. Any suggestions as to the cause of the problem and possible solutions would be greatly appreciated. An additional comment -- while the machine has been exposed to the normal house environment, there has been no abnormal house repair activity which might create a dust problem. Unfortunately, the nearest Pioneer certified repair center is a good 2 hours plus car ride away and so I felt I should look for a simple solution first, if one existed.....
    Sergeant:
  • 308 Answers
If the unit will not recognize any discs, then I would suspect a weak laser pickup, assuming the lens is clean.
Posted on Jan 01, 2007
I have a Magnavox MRV700VR. I can record on a DVDR, but when I try to record on a DVDRW it tells me "disc error". Why?
It will be either that you have not formatted the disc or that you are using the wrong type of disc. You will need a DVD+RW on a + machine or DVD-RW on a - machine. Most recorders will playback the other type but not record on it.
Jan 28, 2013 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am attempting to burn a disc off of idvd and after inserting the ativa disc it ejects it and says to insert a recordable disc. Any ideas why? The disc are new just opened.
Try another blank disk. When you put it in, do not click on any prompts or anything like that. It is possible something got burned on the bottom of the disk. It is also possible, you need to use a CDROM and not a DVDRROM. Also, if you look at the bottom of the disk, you will see a section of a different color starting from the middle and moving out if there is any information on the disk.
Thanks for using FixYa!
Jul 24, 2011 | Office Depot Ativa DVDR Recordable Media...
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Disc indicates "disc full" after only a couple minutes of recordi
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Dec 26, 2008 | Philips CDR770 CD Recorder
Samsung DVD recorder
check the compatability of the blanks does recorder work with dvd disc you are using dvdr+, dvdr-, rewritable?
Jul 30, 2008 | Televison & Video
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Phillips DVD Player / Recorder
Slot under front edge of player will allow you to eject by sliding lever with a small pointed object
Nov 03, 2007 | Philips DVDR 3355 DVD Recorder
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Jul 21, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Problems finalizing discs
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Nov 02, 2006 | Toshiba DR4 DVD Recorder
Pioneer DVR-530H-S DVD Player/HDD Recorder Logo
156 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
