Question about HP Officejet 5610 All-In-One InkJet Printer
Paper jam how to get the paper out
The paper is business cards
  • 28 Answers
Just unplug the power cord and at the back of the printer theres a tab you can press to open the access door and you can found the paper there.
Posted on Nov 22, 2008
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
Bizhub 420 paper keeps jamming
ok then open the section that the paper goes in take a business card a shove it down all along the hole area where the paper goes something is stuck and the document are hitting it hope fully the business card is strong enough to push what ever is blocking it away
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 10, 2014 | Konica Minolta Office Equipment & Supplies
REMOVE PAPER TRAY TO CLEAR PAPER JAM
This may help. Only feed business card paper through the manual feed tray. Good luck.
Sep 10, 2012 | Dell 946 All-In-One InkJet Printer
Paper is jamming
IS this the document feeder section where the orginals is placed, mite check for a staple, paper clip, torn paper left over or a mylar mite have flipped.take a business card and stick it in the paper path you mite be able push the mylar back out. maybe some tape got in there or a 3m sticket.
Aug 13, 2009 | Sharp Office Equipment & Supplies
Jammed card stock
This machine has auto paper type sensor- may be at fault
May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
Paper is jamming when I print something
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Apr 18, 2009 | HP Color LaserJet 2600n Printer
Trouble printing Clean Edge business cards
not tru. you need to go to printer set up and chane the setting to heavy paper so that the fuser will fuse the toner in to the card stock
Dec 03, 2008 | Brother MFC-465CN InkJet Printer
Load mpf paper
Your printer is set to default to the Main Paper Feeder, which is probably set for letter size paper. You must tell it to feed cards. On your Windows Desktop, left click mouse on START. left click on CONTROL PANEL, and left click on the PRINTERS icon. On the PRINTERS screen, RIGHT CLICK on your Dell printer icon. On the drop down menu, left click on PRINTING PREFERENCES. On the PRINTING PREFERENCES window, left click on the PAPER/QUALITY tab. Under TRAY SELECTION, choose the PAPER SOURCE where you want your business cards to feed from. Left click on APPLY button. Next, left click on the ADVANCED button. On the ADVANCED OPTIONS window, use the drop-down box next to PAPER SIZE to choose the paper size you want to feed. Press OK button. The PRINTING PREFERENCES window will now reappear. Left click APPLY, then OK buttons. After you have printed your cards, be sure to restore the printer defaults back to their original state, or the printer may jam because it must be programmed for the paper size being used. If you reload letter paper without resetting the paper size, the printer will think there is still card sized paper in the tray, and it will issue a jam or error code until the paper size is set properly.
Jul 30, 2008 | Dell 3100cn Laser Printer
Repeated paper jam in fuser
Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
Their may still be some card in fuser causing jams.
Please rate as FIxya or post back,
Cheers
S. :-)
Jan 01, 2008 | OKI C5200n Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
