Question about Reddy R60A Utility Heater
Heater will not stay running
I have a Remington 60 kerosene heater. When I plug it in, it ignites and runs for about 5 seconds and then quits. There is an adjustment screw on the back and I have gotten the heater to run up to 10 seconds and then when it tries to run at full force it quits again.
  • 5 more comments
  • tdalecollins Nov 20, 2008
    My Ready Heater Pro110 will start and run about 15 min. and then stop.
    I push the reset and it will run about 5 sec and stop. The next time I push the reset it would not run at all. I can wait about an hour and the the whole process will happen again.
  • Anonymous Dec 08, 2008
    Same thing here...
  • Anonymous Dec 10, 2008
    my ready heater r60 will light and run about 5 minutes and go off then i unplug and replug and it will run about 5 seconds . let it set for a while and process starts over again
  • Anonymous Dec 14, 2008
    quits-wont keep running
  • vinman713 Jan 13, 2009
    i have a r 60 i plug it in i here the fan turn on i see it glowing then some smoke then it turns off
  • spinmanbob Jan 13, 2009
    my reddy heater 60000 btu heater does the same thing, but when I remove the lid and handle assembly, it runs just fine. The only thing I can think this might is the photocell inside the housing. I think this is a safety device that shuts the heater down when the flame is gone. That part might be bad, but I dont know for sure
  • caligator Apr 11, 2009
    My 60,000 btu heater quits after 5 seconds also. With the lid off it will run continuously.
  • 232 Answers
Spark plug or hot surface ignitor?
Posted on Nov 19, 2008
Ready Heater 60 wont start. Fan runs for about 5 seconds and then stops.
Check the wires for good connections. If the connections are good, then check the adjustment for the ignitor (sparker or glowplug).
Feb 10, 2011 | Reddy Heater 60,000 BTU Kerosene...
Remington torpedo kerosene heater will not stay running?
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 17, 2011 | Heating & Cooling
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy R60A Utility Heater Logo
1,288 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
