Question about AudioBahn A2801Q Car Audio Amplifier
Just wondering ..
I have (2) 12' kenwood subs an im wondering what box to put em in to get the best sound ...
    Scholar:
  • 96 Answers
Square port (slot loaded) vented box tuned at 33 - 38 hz is the loudest deepest bass you can get
Posted on Jan 10, 2009
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I have a 2011 gmc sierra and im putting a kicker comp vr 12 in there and i was wondering how much airspace i would need the box im looking @ is .98 i hope its enough airspace and its ported box
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch sub the box size will be 13 inches x 13 inches x 13 inches. Hope this helps
Dec 04, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Best sub For RF T10001
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Dec 13, 2008 | Rockford Fosgate T10001 bd Car Audio...
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
1500w duel coil subwoofer
Depends on the type of music you listen to and the type of sound you want out of the box. If you're looking for "as loud as possible", you'll probably want a ported box, as this will make the output of the sub peak at a specific frequency and drop off at others. If you wanted more of an even response across many frequencies, a sealed box is probably best. Kenwood has recommended sizes in the owner's manual.
Mar 25, 2008 | Kenwood KFC-W3514DVC Car Subwoofer
12" kicker l7
It sounds like the "flex" surrounding your SUB has not been flexed properly. When it comes to SUBS, if you can't fix it in the 1st hr. Its better to replace em.
Try pushing on your SUB repeatedly for about 3-5mins. Working the "flex" on it. If there still is not give in it, time to replace.
Feb 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sub box inner space measurements in inches
First off I have some questions to ask you? what size are your subs and what is the max power on them and the brand name?
Dec 18, 2007 | Car Audio & Video
Sub out put problems
Change the amp ground to the same one as the head unit.
That will cancel out the noise.
Best of Luck.
Oct 26, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
AudioBahn A2801Q Car Audio Amplifier Logo
55 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
