Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
External speaker hook-up
I have the Akai PDP4298 plasma TV and have never used the two speakers that came with the TV (I have always used surround sound speakers), but want to use them now.  The back of the speakers have normal clip in speaker wire connectors, but to connect them to the TV it has a different set up and I need an adapter of some sort.  It says 8 and the greek letter Omega.  The connector needs  to be something that is double female for the right speaker and then a double female for the right speaker.  I have been looking around and asking for help at Best Buy and Radio Shack but no one can help me.  I have tried different sizes of banana plugs and they don't work either.  Can you help me?
thank you,
travis
  • Timwetzel Jan 09, 2009
    I have the same problem. Any luck solving this problem?
  • alohamela Jan 14, 2009
    I have the same problem too. The red and black connection on the speakers are ok; its just the connection in the back of the TV that is hard. The bare wires don't stay connected and keep falling out if you move the TV and I don't know what connection to ask for without taking the whole thing to the store.
    Does anyone know what connector to use for the back of the TV set?
    Mahalo. (Thanks)
Ok, after A LOT of internet research I could not find any solution. So I decided to do a "chop suey" connection.
Went to Radio Shack and bought ...
Insulated Grip 2-1/4"Alligator Clips w/screw terminals 10 (five red & five black)
(A smaller alligator clip can be used if you have a soldering iron to connect the wires.)
30-Ft. 18-Gauge Clear 2-Conductor Speaker Wire
It cost about $15 for everything. Be sure to have electrical tape as well.
Stripped speaker wires to fit through each alligator clip and twisted it around the screw terminals of clip. Tapped screw terminal to cover wiring. Do this for 2 black and 2 red clips.
To install l laid the TV on its back and insterted each alligator clip to firmly fit on each terminal. Because the clips are large it will be a tight next to each other. Be sure to test one line and speaker first before completed the second line and speaker.
GOOD LUCK!
Posted on Jan 15, 2009
Just strip the wires and push the tab back, then push the wire in the hole that opens up. Release the tab. One red and one black for the left and then the same for the right.
Posted on Jan 04, 2009
How to remove the speakers?
why? If you are planning to use surround sound just turn the speaker all the way down on you tv and listen to the sound through the surround sound speakers.
Oct 10, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
Akai 4298 plasma....sound no picture, lost manual...any help?
Check the power supply board, Z-SUSTAIN board, Y-sustain board for blown fuses and caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps
Jan 13, 2011 | Akai PDP4298 Television
I need to know what input & output connections are available on the Akai PDP4290 Plasma TV?
This was the cheapest Akai in its day. No Tuner, No Speakers, must use a surround sound or regular stereo amp for sound.
It also has the standard A/V input also.
Best to use a HD Box and RGB cables for best picture.
Dec 04, 2010 | Akai PDP4290 42 in. EDTV-Ready Plasma...
My tv has sound but no image where can i start searching?
there is an answer here on this forum that helped me fix the akai pdp4294 with the same exact problem, which is basically the same tv internally.the problem was two capacitors on the power supply unit board.the answer to the thread shows pictures and which capacitors to replace,email me if you have any questions ,mesa1965@gmail.com
Dec 26, 2009 | Akai PDP4298 Television
No sound
The speakers on these are usually at the bottom and do come off the set. If they are on the TV make sure there are wires connecting the speakers to the back of the TV at the speaker terminals.
Dec 28, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
How to get surround sound
Make Sure the correct sound filed is being used refer to owners manual and the program is true surround also the surround speakers will only give background noise not a full channel
Oct 04, 2008 | Televison & Video
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
May 23, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Akai pdp4298 42 in. plasma
The clicking sound is the relay switch on the power board, it could be the power board or the logic board
Sep 03, 2006 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
416 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
