Question about Sharp AL 1631 Copier
Copier Locks up L1 Error Code
I looked it up in the manual and it says that the copier is locked. Actually its a 1645CS. I unlocked it, turned it off and back on again but I still get the same error. The copier barely starts up and quickly locks up.
  • 9 more comments
  • wmfanton Nov 19, 2007
    I'm having the same poblem and have torn the thing apart and made sure everything is clear and lubed. Still get the same code.
  • Latoya Newso Dec 17, 2007
    my copier acts like it want to copy the l1 light is blinking when i cut it on it off it will start to roll nothing come out been setting up for a year at least in the old office storage room a green light stays on at the bottom diagram on the front the auto lights stays on and the only time it change is when i push the ^ button up for how many copies cut it on and off but it goes back to l1 error and none of the others button will work are change the paper size are zoom area my c button want work either.
    l1 light comes on no button work green auto light stays on been in storage office for a year.
  • jtemores Jan 22, 2008
    what is main pcb?
  • Pedro Torres Jun 07, 2008
    Me sale el error H3, en la Fotocopiadora AL 1645Cs
  • lawyer 1776 Jun 10, 2008
    copier not printing displays blinking L 1 light
  • KING6 Jun 30, 2008
    COPIER LOCKED UP AND L1 ERROR CODE
  • Anonymous Sep 25, 2008
    L1 message
  • Anonymous Oct 06, 2008
    i get a l1 but where is the sharp al-1631 lock
  • miecarr Jan 14, 2009
    i have this problem too. i unlocked it and it still is giving me the error code, what could i do?
  • Anonymous Apr 07, 2009
    SHARP AL 1631 COPIER MODEL SF-7320 L1 ERROR CODE HOW DO I FIX.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
"I've had this trouble recently. The lock switch is not so a lock switch but a circle object to the left of the printer and under the scanning part. I had to turn all the way to the unlock side and restart the copier.
What Bad place to put an lock/unlock switch"
This lock switch is for Transport,
It locks the Scanner, so as to not damage while in transport.
When installing/setting up the machine this should be removed?
If not sometimes people accidently bump it to lock position.
It can be easily removed with a Flat Screw driver. It will pop out easily..
Posted on Oct 30, 2008
There is a locking dial under the left side of the machine that maybey holding the scanner in home position.... be sure its unlocked.
Posted on Dec 17, 2006
  • 3 Answers
It's possible the rail for the scanner has become gummed up. Remove the glass and use light oil, (tri-flow, 3-in-1, etc) on rail.
Posted on Jul 27, 2007
Posted on Sep 17, 2008
The copier is printing a dark black line vertically on the paper. I have cleaned the transfer charger and ckecked the toner cartridge. How can I get rid of these lines?
Posted on Dec 13, 2007
If unlocking and lubing the scanner rail does not work it will be the main pcb
Posted on Nov 19, 2007
  • 4 Answers
First run a copy from the glass and one from the document feeder. If the line is only visible when running copies from the document feeder the problem is a dirty scanner glass. Clean the small piece of glass on the right hand side next to the larger original glass. Old style lighter fluid works best like Ronsonal or Zippo.(wick type - not butane) 2. If the problem shows in both copies you will most likely need a new drum unit, but you may be able to solve the problem by removing the drum from the holder by expanding the rear frame slightly until you can lift the drum out and then blowing out the charger unit above the drum with compressed can air. Reinstall the drum in the holder and check copy. ALWAYS HANDLE THE DRUM WITH A SOFT PAPER TOWEL - DO NOT TOUCH THE DRUM SURFACE or allow it to bump against hard surfaces.
Posted on Mar 30, 2008
3 Suggested Answers
SOURCE: L1 Error Code
turn on the lamp? ,
Posted on May 24, 2007
  • 62 Answers
Check under left side clear pastics were the paper comes locks scanner in place.
Posted on Oct 10, 2007
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
L1 error mesmo tirando trava do scanner e trocando placa logica e cabo flexivel
I Don't speak Spanish but if your toshiba e-Studio is having an L1 error it likely means that your scanner is locked, if you reach into the output tray there is a knob on the front left hand side that locks your scanner in place. Turn it and your copier should work again.
Oct 05, 2010 | Toshiba e-Studio120 Copier
The Sharp AL-1540CS copier produced a sheet all black then gave the error code L-1. The manual said to ''unlock'' the scan head lock, but after looking, it was already unlocked. After restarting the...
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Apr 13, 2010 | Office Equipment & Supplies
My boss has a Sharp AL-1655CS Copy Machine and it makes this awful, screatching noise when I try to copy anything. Now the System Error Code L1-00 shows up. Not sure what to do.
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
Jan 12, 2010 | Sharp AL-1655CS Copier
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
System Error L1-00
Most of the time the scanner is locked. There is a clear plastic lock located under the scanner. Look on th e top in the opening where the paper comes out, one way locks the scanner for transport the other unlocks it for use...
May 23, 2008 | Toshiba e-Studio162D Copier
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Error L1-00
Yes, ,there is a clear plastic round thing where the paper comes out uder the scanner that locks or unlocks the scan head. turn it to unlock.
Dec 10, 2007 | Sharp AL-1655CS Laser Printer
L1 Error Code
Dec 09, 2006 | Sharp AL 1215 Black and White Copier
Sharp AL 1631 Copier Logo
2,283 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
