Question about Sharp AL 1215 Black and White Copier
L1 Error Code
I looked it up in the manual and it says that the copier is locked. Actually its a 1645CS. I unlocked it, turned it off and back on again but I still get the same error. The copier barely starts up and quickly locks up.
  • 62 Answers
Check under left side clear pastics were the paper comes locks scanner in place.
Posted on Oct 10, 2007
Turn on the lamp? ,
Posted on May 24, 2007
  • ramirez cruz May 24, 2007
    l1 lo indica cuando la lampara no enciende o no tiene la intensidad adecuada
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
The Sharp AL-1540CS copier produced a sheet all black then gave the error code L-1. The manual said to ''unlock'' the scan head lock, but after looking, it was already unlocked. After restarting the...
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Apr 13, 2010 | Office Equipment & Supplies
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
Error code "L" & "1"
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
Jul 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
System Error L1-00
Most of the time the scanner is locked. There is a clear plastic lock located under the scanner. Look on th e top in the opening where the paper comes out, one way locks the scanner for transport the other unlocks it for use...
May 23, 2008 | Toshiba e-Studio162D Copier
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Error L1-00
Yes, ,there is a clear plastic round thing where the paper comes out uder the scanner that locks or unlocks the scan head. turn it to unlock.
Dec 10, 2007 | Sharp AL-1655CS Laser Printer
Copier Locks up L1 Error Code
there is a locking dial under the left side of the machine that maybey holding the scanner in home position.... be sure its unlocked.
Dec 09, 2006 | Sharp AL 1631 Copier
Sharp AL 1215 Black and White Copier Logo
120 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
