Question about Acer Aspire 5050-3242 Notebook
Cannot connect to mobile broadband?
I bought a acer aspire one and a '3' gongle to go online, apparantly the gongle is a case of plugging in and follow installation wizard, after tryin this with no success i rung acer to be advised to get live updates via my braodband ethernet cable at home, which should update my notebook to accept the gongle.. still no luck? this notebook doesnt have windows which makes it more difficult to solve this problem... please help.
simon
  • Desktopsbyduck-Computers
    Simon what os are you running.i can help if you provide me this info.RICHARDM69
I just got an Acer Aspire One AO532h-2588 netbook. I currently use a Sprint mobile usb broadband stick. It will nto let me instaall the stick to connect to the mobile broadband. I can find no help or...
There is a possibility that the USB stick may not be compatible with the new operating system. You should first contact Sprint to verify that it will work with your OS. Give them the model number of the broadband stick and the name of your operating system and whether it is 32 or 64-bit. If it is compatible, they should also be able to direct you in the correct procedure to install the device.
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Windows 7 on aspire one AOA150, built in modem doesn't work
After installing Windows 7 and any other new applications, please ensure that you have loaded ALL the required W7 drivers for your specific Aspire One especially the CHIPSET supports driver (if not, plug-in devices and other inbuilt devices like sound, modem, usb or video will not work properly). Hope it helps. Let me know how you go!
Dec 31, 2009 | Acer Aspire One AOA110-1113 Netbook
3 g dongle
the only way to connect this
is you will have connect your laptop to normal internet such as bt for a few mins /vear ethernet lead /
then down load mobile partner
install this to your laptop/
disconnect ethernet / plug usb 3 in /open mobile partner/ and this should see it then connect
Aug 28, 2009 | Acer Aspire One AOA150-1784 Netbook
Have to press F2 to continue set-up on Acer aspire
Have you tried running a spyware ckecker?
Try http://www.spybot.de
Jul 11, 2009 | Acer Aspire AS5920-6914 Widescreen Laptop
Inter net connection
Try to reconfigure your wireless so that your broadband is controlling your wireless instead of the Acer.
Jun 17, 2008 | Acer Aspire 5315 Notebook
Wireless
check two things..
This link to their online manual.
Make certain on the front panel, that the fourth switch from the left, which controls the wireless, in enabled. There's a light there that will tell you whether that's the case or not.
Got backup?
Feb 07, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5315 with Windows Vista Home Basic will not connect wirelessly to our router but will connect to others.
hi i have just bought a Acer Aspire 5315 on vista i wanted to put it back to factory reset but it seems that they have taken out the back up to do this can i get a disc from any were or any help i would be most greatful thanks dee
Jan 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5050-3242 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
