Question about Sony KDS-R50XBR1 50" HDTV
Yellow spots The problem I am having is some yellow spots have formed on the top right side of my tv. Although you can still see the picture, there is a yellow tint. I was just wondering if there was anyway to remove the yellow spot without calling the tech.
  • Ridg Dec 11, 2007
    A large yellow spot remains on my screen as well as yellow tinting around images especially in cartoons with white backgrounds.
I have no suggestions but I am having the exact problem, yellow haze in the top right corner of the screen with a yellow line running down to the bottom of the screen. I guess we need to call tech support.
Posted on Jan 07, 2007
  • Steve McMahon Jan 10, 2007
    Ok...here is the solution directly from Sony:
    Unplug the TV from the wall or surge protector. Let the TV sit for 5 minutes. Plug the TV directly into the wall outlet. Turn on TV, yellow haze should be gone. Do not use surge protector anymore.
    The rep told me the problem comes because of the surge protector (and I have a good one). He said the owners manual says to plug the TV directly into a wall outlet so if a problem occurs the warranty is still good.
    I hope this works for you as it did for me.
I have this television model and it has the same problem. Sony is repairing this issue free of charge, it is called the optical block replacement. go to this site for assistance: http://esupport.sony.com/perl/news-item.pl?news_id=185&mdl=KDSR50XBR1
Posted on Oct 09, 2007
Its a problem with a part called the "Optical Block". Call Sony again and tell them about you issue again.
Posted on May 20, 2007
Scren went blank. We have sound but no picture .what do we neen to do to get pictute?
How is your TV receiving video? Are all cables connected? With RCA (the red, yellow, white ended cables) the yellow is the video, the white and red are left and right stereo sound. Ensure that all cables are connected into the correct spot on the back of the TV and that you are on the right input (Video 1, AV1, etc).
Mar 15, 2015 | Sanyo DP55441 55" LCD TV 1920x1080, 120...
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
My wii has power but no picyure why?
Check The cables that connect to the TV. Make sure that the cable is securely connected to the console. Next make sure that if your using the Red, White, Yellow composite cables everything lined up. Yellow is video and should go with the slot labeled video on the TV or the yellow slot on the TV. Red is right audio and should be put in the labeled spot for right audio on the TV or with the red spot on the TV. Lastly white is left audio and should be put in the spot that is labeled left audio on the TV or in the white spot on the TV. If all of the cables are hooked up like so, and everything is secure yet there is still no picture, you need to buy a new cable because it seems that one may have been damaged. If there is still no picture with the new cable, then your last option is to try it with another TV. If it works with the other TV, the 1st TV your trying to put it on has a faulty composite input. If it still doesn't work on the other 2nd TV, then there is an internal problem with the Wii and needs to be repaired or replaced.
Hope this helps!
-MarcusTuttle
Jul 17, 2010 | Nintendo Wii Console
Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Feb 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No picture
on tv select corect input ok video 1 ect make sure cable out from dvd is in right spot yellow out and in the video in yellow on tv ect
Jan 24, 2008 | Panasonic sa-ht930 Home Theater Audio...
Green spot on picture
Greenish yellow spot only means one thing. You have a defective lite engine. The only fix is to replace the engine. This part is very
expensive. Average cost $835.00 Part number A-1606-008-A
Best regards
circuitcity
Dec 08, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Yellow Spot dead center on screen
most likely the yellow dot is due to a burn in the picture on the "green" lens. It's not removable because it's burned it, but you can try cleaning it because sometimes, dots are caused by dirt. The worst that can occur is that if the dot is permanant.
Feb 14, 2006 | RCA MM61110 61" Rear Projection Television
Sony KDS-R50XBR1 50" HDTV Logo
661 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
