Zenith Trans Oceanic Reception
I have an old Zenith Trans Oceanic L-600 that is in very nice condition, however it recently started to develop a lot of static and a noticeable decrease in the volume after it warms up.
Does anyone know if this is a common problem and a possible solution?
I am not sure, but it sure sounds like the filter capacitors on the input from the power supply are shot. What may be happening is as the radio heats up the caps are breaking down and allowing unfiltered dc into the circuit. It can cause the kind of noise you are talking about. If that is your problem it is the ac going back and forth (alternating between positive and negative current 60 times or cycles per second) By the way cycles per second (cps) is now called hertz. (hz.). Recaping or having all the paper and electrolytic capacitors replaced in your radio may solve the problem. Consult a quality radio service center.
Keith
Posted on Dec 03, 2008
Konica bizhub 600 after scaning show now printing
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Dec 26, 2016 | Konica Minolta bizhub Office Equipment &...
WONT SHIFT INTO OVERDRIVE UNTIL IT WARMS UP??
have the trans fluid checked and changed if not been changed recently as a starting point , a lot of trans problems are due to the trans fluid level, condition etc
Mar 23, 2015 | 2007 Toyota Yaris
C2801
Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
May 05, 2014 | Konica Minolta Bizhub 501 Copier
PROCEDURE CHANGE DEVELOPER KONICA BIZHUB 600
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
Why I cant get reception in my parking garage?
GPS reception may be inconsistent in certain locations or under certain conditions. In most parking garages and underground parking lots you won't be able to get a GPS reception because the signal is blocked by the concrete.
Feb 06, 2013 | Home Security
My bizhub 600 is showing message warming up ready for next copy
Sir/Mam,
Mar 31, 2012 | Konica Minolta Bizhub 600 750 Image...
Bike wont run when choke is at half way setting
Sounds a lot like fouled fuel jets in your carb; you may have a little work to do.
If the jets do not allow sufficient fuel to pass, using the choke can 'cheat' the carburetor by restricting the flow of air and restoring the fuel-air ratio. You can't ignore this problem since the 'cheated' condition does not let the engine develop the power for which it was designed.
Apr 26, 2009 | 1988 Honda CBR 600 F Hurricane
DIAGONAL LINES LG PLASMA
Find out the board number, contact LG Zenith company tell them your problem.This way it lets you know wheather or not you want to fix it ask them how much is board.www.LG zenith.com. Good Luck. ThankYou for using FixYa. Have a NIce Day.
Feb 08, 2008 | Televison & Video
Zenith M52W56LCD blue spot in center of screen
It could be as simple as dust contamination in the LE or lcd chip. You need a clean room to work on this area of the unit and NOTHING you can do there would make that possible, short of spending a few thousand to build one. Before we added a clean room enviroment we simply pulled the LE and sent it in to PTS - who has one and reinstalled...
In your case take it to a qualified shop and you'll save yourself a lot of grief..
Bill
Nov 19, 2007 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
