Question about ASUS P4P800 SE (890552603657) Motherboard
Asus P4p800 se Mainboard USb Ports not working
Dear Sir! I have problem with my Asus mainboard, All (8) USB ports are enabled in bios setup but all ports are still silent when i connect any usb device or keyboard,mouse. I checked device manager all usb controler are installed properly.But not work, window XP(SP2) instaled on my pc. Pease help me and send a proper solution. Thanks
  • ASUS Master
  • 4,806 Answers
It would seem that you are not the only one with this problem with the USB's, the only soloution i have found that people say works is to reset the cmos (remove motherboard battery without any power cord attached) for 10 mins, or, go into the bios and reset to default/optomised defaults
hope this helps
kind regards
Posted on Nov 18, 2008
P4P800 SE - UAYZ BIOS
Hello you can find drivers and the manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4P800%20SE&p=1&s=15
You just have to select your windows system.
Any file from here needs to be unziped, before you install the driver.
Good luck
Mar 26, 2013 | Intel ASUS P4P800 SE-UAYZ 800FSB P4...
P4p800 se-uayz
When upgrading the bios you have to make sure, its the right mainboard bios file.
Open the case and look for the mainboard number.
Flashing the bios with a wrong one, will destroy the mainboard !!!!
Good luck
My printer is plugged into one of the two usb ports at the front but I got a message saying it would run faster if it was plugged into a high speed port which when I checked it says I have 8 of but where...
Usually the main usb ports for the pc will be on the rear panel of the machine. If you feel safe to do so, switch the machine off and unplug from the power source, remove the side of the machine and touch a piece of bare metal on the chassis to remove any static build up in your body, then have a look around on your mainboard, try to trace the cable from the front usb connections to the mainboard, and see if there is a usb2 version of the socket which they are plugged into, swapping to this may solve your problem.
Hope this has been helpful.
May 06, 2011 | Dell Dimension 3100 PC Desktop
P4p800 se motherboard. usb doesn't work
you can purchase add-on p[ci usb cards for around $25 at a store such as best buy or online.
May 24, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Asus logo comes up on boot but cant enter bios or anything else beccouse the keyboard doesn't work. I'we tryied other keyboards bbut they don't work to so i can't enter bios or install Windows my...
Most Asus motherboards by default have the USB ports enabled in the bios.
Buy the item, Y adapter below to bypass the PS/2 keyboard port on the motherboard; http://www.cablestogo.com/product.asp?cat_id=1538&sku=27225
You should be able to enter the bios using a USB port. Or buy a single PS/2 to USB; http://www.cablestogo.com/product.asp?cat_id=1538&sku=35700
Cheers'
Mike
Jan 20, 2010 | ASUS P4P800-E Deluxe Motherboard
PCI Simple Communications Controller, seem not to function
Hello my friend
First your motherboard does not support windows 7 and the maximum ram capacity is 4GB DDR400/333/266 non-ECC DDR SDRAM memory
Second you can go here and check which memory your motherboard supports
P4P800 SE Memory QV
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/P4P800_SE_QVL.pdf
Third you can try updating your Bios,more information in your manual
MANUAL
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
your motherboard details is here
http://www.asus.com/product.aspx?P_ID=YNlDkmz5gSNpiCr6&templete=2
Good luck
Jan 14, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
How to upgrade to hi-speed USB ports?
you answered it yourself.
"how can i upgrade my motherboard!"
add a pci sub 2 controller.
Nov 29, 2008 | ASUS P4P800 SE (890552603657) Motherboard
NO USB WORKING
Hi there what OS do you have loaded?
Im assuming you have XP loaded.....
have you tried to unistall and reinstall the USB ports?
reboot and restart,
should auto recognise the device and self install,
reboot and restart,Test usb
dont for get SP2 updates for functionality of the devices
Let me know the outcome thanks
Jul 21, 2008 | ASUS P4P800-MX Motherboard
Not recognizing USB Memory Card
check the BIOS settings to turn on USB ports.
Oct 10, 2007 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
346 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
