Question about Canon PIXMA MX700 All-In-One InkJet Printer
Error Code 6A80
Tried turning the machine off and unplugging, but when I turn it back on, same error code appears.
  • Canon Master
  • 1,879 Answers
The error code means : Part of the paper was ripped inside after a paper jam issue, or there is a foreign object stuck inside the printer.
If the error still shows after checking inside the unit for any obstruction or objects, the unit requires service.
Posted on Nov 18, 2008
    Scholar:
  • 181 Answers
If you get this error after a paper jam, probably that paper was ripped inside, and one pice is stucked somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
  • fixyy Nov 18, 2008
    For troubleshooting purposes please follow these steps:
    1. Look in the top of the printer, where the paper feeds from. Make sure there aren't any paper clips or thumbtacks or something like that in the paper path.
    2. Turn the unit around to the rear. In the back of the printer there is a door that can be opened. Open the door and look for any foreign object or smaller pieces of paper that may have stuck in the printer.
    Close the door after inspection.
    3. Open the front door to the unit. Make sure there are no foreign objects or stuck paper in the location where the paper comes out after printing.
    After inspecting all of these locations, reconnect the power cord and turn the unit on.
  • Canon Master
  • 13,433 Answers
6A80 would seem to be related to a paper jam, remove the paper jam and press the on off button to restart the printer.
  • Ekse Nov 18, 2008
    The paper is most likely stuck inside the printer
    1. Push the rear cover tab to the right and pull out the rear cover.
    2. If you can see the jammed paper, remove it gently.
    Note : Avoid touching the inner parts. If you cannot pull out the paper, turn off the machine and turn it on again. The paper will be ejected automatically.
    3. Insert the protrusions of the rear cover into the slots at the rear of the machine and press the tab to attach the rear cover.
    4. Turn on the machine and confirm that the Alarm lamp is turned off.
    5. Load paper to resume printing.
Error code 01241 on singer quantun XL 6000 ??
unplug machine for 5 min and replug into electrical outlet. resets it.
Feb 18, 2015 | Singer Quantum XL-6000 Computerized Sewing...
Hi, I have a "dead"
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
for more info visit: http://pcmediks.blogspot.com
Dec 28, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error code 6A80, won't print after changing ink cartridge. printhead is all the way to left. Tried moving it manually and turning off and unplugging printer.
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Jun 30, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Printer error 6A80 when printer is turned on. No paper jam noted. Tried unplugging, and turning off and on.
6A80
6a90
c000
6C10 feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective.
Troubles with purge pump and or purge tube plugged (clogged). Needs service tech.
Nov 24, 2009 | Canon PIXMA MP620 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Service Error 6A80
That error says there is something jammed in either the purge assembly or the sheet feeder on the back not able to turn. The purge assembly is on the right where the printhead parks for cleaning.
Oct 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code "sr"
Sr is a stuck relay on your main board.Replace your pc board.
Dec 30, 2007 | Maytag MAH8700A Front Load Washer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
Corne Viljoen
