Question about Motorola Mobility RAZR V3
Screen dysplay does not light when opening the cover or calling
Screen does not light up when opening the phone
I fixed the display problem that I was experiencing by removing the battery and replacing it and restarting the phone
Posted on Nov 19, 2008
Buttons light up, screen is black/blank
your phone has a dead led screen go to amazon and look up the model and replace the screen
Feb 02, 2018 | Samsung Stratosphere
Lg bl40 screen works mostly fine. but when receiving calls, answer and reject button do not respond on touch. so, calls remain unanswered. pls help! Nikos, Greece
I had the same problem. The reason was that I had bought a cover for the phone and the cover would make the proximity sensor turn on and so the screen would be locked. If you've bought a cover for it, this may help.
Apr 04, 2011 | LG CHOCOLATE BL40 (1 GB) Cell Phone
Droped my voyager and now the screens are blank
The problem could be that the screws that attached the screen of your phone to it panel might be loose.
All you need do is to power off the phone, remove the battery cover,battery and sim card. turn the phone over and, gently remove the front cover or casing, it just pulls off.
Get a torx6 screw driver to tighten all the screws on the screen of your phone very well and couple back.
Put the sim card and your battery and power on, if the screen did not still come on, it means the flex on the screen of your phone is bad and will need to be replaced.
Replace the flex of your phone screen if tightening the screws of the screen did not solve the problem. change the flex of the screen of your phone and you will see that your phone will display.
Take care.
May 21, 2010 | LG VOYAGER VX10000 Cellular Phone
My phone scrren wont light up. i had left my phone in the bathroom while i was bathing and the room was filled steam.When i come out of the bathroom i check my phone and the screen was covered in steam....
the worst for phone is water damage.in your case lcd is damage.must change.but its not guarantee for property work on your mobile cos water may damaged other parts of device.ALWAYS KEEP PHONE FAR OF WATER
Dec 09, 2009 | Sony Ericsson W850i Cellular Phone
Where do the staples go in a bizhub C352
Tha stamples go in a finiscer cover, you have to open front finiscer door and, on the left you can see the stample unit. Stample unit, in normal condiction, is positioned indoor, but you can move it by lcd dysplay funcion (stample chage) or in manual mode by rotation the green herness (stample movement).
Sorry for my bad english.
Bye.
May 14, 2009 | Konica Minolta Office Equipment & Supplies
Virus in my my N72 Nokia Mobile
The only option here is to do a master clear on your device. With this phone the instructions to do this can be found in the manual located HERE. Keep in mind this will delete everything you have installed or entered and reset the device back to the way it was when you first opened the package. This includes programs, addresses, contacts, call log, etc.
Apr 22, 2009 | Nokia N72 Cellular Phone
The inside screen of my envi2 is not working
buy u a set of very small tork scew driver set for phones,ebay has them ,there are 4 scews that holds screen together,carefully open screen cover all around until it snaps off,then trace flex cable down to corner toward hinge,cable should be loose snap back in carefully.,turn your phone on ,hope that helped.
Feb 04, 2009 | Motorola Mobility RAZR V3
Buttons don't work
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Nov 26, 2007 | Motorola Mobility RAZR V3
Problem when I open the phone, please help!
Okay I work for Sprint as a advanced technical support. Your screen is busted I can tell that when you said it was orange. The LCD is non existent and the colors have mixed. I hope for your sake that you have insurance because it is time to get a new phone. and yes when it is closed the sub screen works fine because it is two separate screens and your main screen is the one busted. It is hard to say if you will be able to get your contacts back because in most cases I have seen that information is lost. So it is time to take it to a Sprint Nextel and Repair center. Hope that helps :)
Oct 13, 2007 | Sanyo SCP-7300 / RL-7300 Cellular Phone
Motorola V3
You may have improperly closed the phone when you changed the cover............and messed up the flex cable that connect the display to the main board.
Jul 08, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3 Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
