I have to keep resetting the clock
..I feel that there is a short somewhere. I want this issue resolved because I feel there is a greater problem and this computer is just 3 months old.
Like right now, the clock says 12:46pm when it is actually 3:46pm.
I had to reset it approx. 3 days ago. And, this is ongoing.
I have an Acer X Series 1200/3200. That is the info listed on the pamphlet.
Thanks
  • 4,806 Answers
The cmos battery inside the PC has run out, all you have to do is remove the side panel and look inside at the "motherboard" you will see a battery there, take it out and replace it with a new one, put the side panel back on and set the time and date and it should keep time from then on
hope this helps
kind regards
Posted on Nov 18, 2008
How do I contact customer service by email
If you are unable to resolve your prolems then Dial Tollfree, 1-866-866-2369, for trusted zohomail service. The EmailHelpDesk's zohomail Customer Service Number helps you in solving all your zohomail issues and offering tremendous support services like fixing zohomail account issues, zohomail email issues and others.
Dec 02, 2016 | Computers & Internet
Please wait keeps flashing on the screen and the clock loses time
OEM radio issues. Flashing Time. Radio Not Working... - Drive ...
www.driveaccord.net/.../51717-oem-radio-issues-flashing-time-radio-not...
Sep 20, 2010 - When I reconnected the battery, the radio does not work anymore. ... I reconnected it, turned the key and the clock is still flashing. ... Wait about three minutes or so, and reinstall the fuse. .... Please let us know what it was. .... Naviscreen comes up but I can't do anything with it because the buttons are dead.
Novelty Simpson Jukebox Alarm Clock Radio Homer ... - Fixya
www.fixya.com/search/p94498-novelty...clock/welcome_please_wait
Novelty Simpson Jukebox Alarm Clock Radio Homer Simpson Animated Jukebox Alarm ... ...welcome Please Wait" Every time I try to use any handset the screendisplays ... This keeps flashing for several minutes, and never seems to resolve.
Troubleshooting - Shop - SiriusXM Radio
Jan 16, 2016 | Audio Players & Recorders
Why does my bissell vacuum keep shocking me
Likely you have a short in the wiring somewhere. If you have a powerhead with a power cord that runs through the vacuum hose that might be the problelm. Check your cords closely. Is it possible you are just getting a static elecricity shock due to dry weather? If you think you are getting a shock, stop using the product until you have resolved the issue.
Dec 01, 2014 | Vacuums
I am in Halifax , Canada. My Nexxtech RC travel clock thinks it is in a Daylight Savings zone (which it is not at this time) and keeps re-setting itslef an hour back every day. I tried the reset button...
My sincere apologies for your geographic location at this time of year.
You should contact the Nexxtech customer service department to resolve this issue. They are the experts with their merchandise and should be able to determine if you have a faulty unit - which is possible.
Feb 02, 2018 | NexxTech Travel Alarm Clock (63-8042)
Controls won't work. Displays message: E0 -F2-
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | KitchenAid KERC607 Electric Kitchen Range
2006 Murano the clock keeps reseting itself back to 1:00 every two or three days... Any suggestions
Sounds like you may have a short somewhere or a problem with your battery connection. I would check the battery connection first then check behind the deck. If you still have a problem you may need to chase down the short. Good luck!
Jan 22, 2010 | 2006 Nissan Murano
Hello! I have a Frigidaire (made by Electrolux) Gallery Professional Series gas range/electric oven, model #FGF379WJCA (manufactured in 1998). The appliance came with the house we moved into 2 years ago. ...
for question 1 the wire for the ignitor is bad has to be changed not an easy job if you can live with it itll be ok if not its best to call in a tech or take to repair shop not sure about question 2 sorry
Aug 30, 2009 | Electrolux Frigidaire Professional Series...
1999 a4 horn keeps going off when i turn wheel mainly.
Check your clock spring, and the retainer it's in, if the retainer piece has come apart, it will short somewhere. This can be a very frustrating problem. Take off the airbag and remove steering wheel, then carefully pull steering wheel and check clock spring. Also check horn pad for any foreign object like a screw that could short.
Jul 10, 2009 | 1998 Audi A4
My relay switch keeps tripping and resetting when the key is on, resulting in a draw on the battery and funny running until the battery is dead. I replaced the key ignition but the problem is still there.
You have a dead short somewhere in your wiring. You need to track down the short to resolve this issue. Start by determining which breaker keeps tripping. If it is the main breaker the fault will most likely be in the wires coming from the ignition switch the rest of the breakers. If it is the breaker with gray wire from the ignition switch it will be in the ignition/starting wiring. If it is the breaker that is connected to the gray wire from the ignition switch through a brass bridge bar the short will be found in the horn, turn signal, warning lights, or brake light circuits. If it is the breaker that is connected to the green wire ignition switch it will be in the running lights circuit.
Jun 15, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Lost instruction manual as to how you reset time on clock
Go here to download to your manual:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 30, 2008 | Neff H5470 Microwave Oven
Computers & Internet Logo
81 people viewed this question
Alun Cox
David Payne
David Payne
