Question about Maytag Neptune MDE5500AY Electric Dryer
Getting powerbtpush on button lite comes on but doesn't turn on
Drum turn by hand with resistance. no buzz sound when I push on button
  • 41 Answers
You probably have a blown fuse in the dryer. you can check it yourself if you have an ohm meter with tone. otherwise, you will need to call a repairman. Joe
Posted on Nov 18, 2008
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Heatman - you comments are always dead on. You've help me extend the life of my dry twice. My current problem is this: When starting the dryer, the drum will not rotate, and the motor makes an...
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Jun 10, 2011 | Dryers
When you push the button to start the dryer, all it does is buzz and nothing happens
next time send the model number and brand name,all dryers are not the same!it sounds like a bad motor.open the door,push the door switch in with one hand and with the other spin the drum,while you're spinning the drum have someone push the start button,if the motor starts you'll know the motor is bad but it might run for a while before it does this again or it will do it every time but either way the motor should be changed,also on some dryers if the belt broke it will buzz like when the dryer is down but if yours is more like a humming sound like power is going to the motor but it won't run then it's the motor.
Apr 24, 2011 | Dryers
Just makes a buzzing sound when you turn the start button on.
that is the motor!try this,open the door,with one hand push in the door switch button and hold it in,as you hold in the button spin the drum with your other hand and have someone else push the start button and see if it starts,if it does you have a bad motor,if the drum doesn't spin by hand you could have something stuck in the blower wheel,let me know what you find
Feb 05, 2011 | Frigidaire FEQ1442ES Electric Dryer
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
