Question about Dell 17" Monitor
DELL P780 monitor is working out of scan range change pc setting
  • lindal3 Nov 19, 2008
    I already did and it did not work thank you!
    New Friend:
  • 62 Answers
1. change the system frequency 60 Hz
2. settins change 1024 by 768 pixels
Posted on Nov 19, 2008
How do i fix if my computer scan is out of range
I am assuming you are talking about your monitor. What this message means is that your monitor can't handle the resolution your video card is set to. Re-start your computer and as soon as the first screen goes by (you know the one with all numbers and stuff) start hitting the F8 key. This will start the computer in safe mode which uses a very low resolution (usually 640 x 480). Once you see the display set the resolution to 800x600 which any display can handle. Re-boot and log in again and change the resolution to something higher. Test different settings. If you set one that is too high and you can't see the screen again don't touch anything as the screen will revert back to the previous setting if you do not confirm.
Hope this helps. If it does don't forget to give me a thumbs up.
Aug 29, 2011 | Dell P780 17" CRT Monitor
Out of range problem on a dell crt monitor
You computer monitor is not receiving a signal from your computer system. Be sure to check that all connections are indeed making good contact.
Go through my published guide in this regard, it is entitled
My Computer is not turning on!!! Is it dead!!! No POST!!!
damnor01
Apr 04, 2011 | Dell P780 17" CRT Monitor
My monetir ok pc low display
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Mar 29, 2011 | Dell Optiplex GX280 (99301) Motherboard
Monitor is bright somtimes and sometimes dim
also
hope this helps
don
Feb 27, 2011 | Dell Inspiron 1521 Notebook
Slightly out of focus. Is there an (internal) adjustment, and if so, where?
over time the shadow mask picks up a magnetic charge that interferes with the focus of the electron beams which makes the image look fuzzy or out of focus...to fix this.. most monitors have a deguassing coil/button..look for a DEGAUSS button or in the menu selection on the monitor..Degaussing usually makes a "thunk" sound and the screen will go crazy for a moment ..
May 06, 2009 | Computers & Internet
Blurry resolution and screen smear until it has been running for several minutes
Check the video card first, if you have another vidoe card try it. If that does not shore up the problem the monitor would be a issue, and now a day monitors are dirt cheap even for the LCD monitors so I would look into buying on of those if your inclined to do so.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 29, 2009 | Dell UltraScan P780 (Black) Monitor
Out of scn range
Hi
Click StartGo SettingsControl Panel  Display Settings your screen 1024*768 select  it and 32 bit color quality also.. apply it ok..
it will work.
Nov 18, 2008 | Dell P780 17" CRT Monitor
Dell Trinitron Ultra Scan Monitors
Yes as long as your monitors have the standard 15 pin Mini D-sub connector (which they do) then you should have no problems viewing a composite input through your converters.
Jan 04, 2008 | Dell Ultra Scan 17TX - 17" SVGA Color...
Dell P780 17" CRT Monitor(3 yrs old) issue
That sounds like a monitor issue, not a video card. Gradual fading means components within the monitor are wearing out. However, I strongly advice against attempting repairs. CRT monitors hold a strong electrical charge. People have been injured and even killed by attempting to work on them without proper tools and training. A 17" CRT monitor is too cheap to be worth the risk (you can often get them used... I got mine for $20 at Goodwill).
Aug 22, 2007 | Dell P780 17" CRT Monitor
Monitor is working out of scan range
It probabily happens after you change the settings of display in control panel (windows), if so restart the machine and press function key <F8> after memory test and you shoud get to the startup menu, choose VGA mode and undo the changes in display that you have made.
Best Regards
Creon
Mar 30, 2006 | Dell P780 17" CRT Monitor
Dell 17" Monitor Logo
63 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
