Question about HP DeskJet 3550 InkJet Printer
Printer problem with HP 3550 deskjet printer
Hi, can you help? I have just replaced the ink cartridge in my HP deskjet printer and it wont print. Took it back and was told it was possibly air pockets - it was replaced but still won't work - cheers
  • maureen_shev Nov 18, 2008
    Thanks for your tip - it was removed but still the ink won't come through - cheers again
  • Anonymous Jan 01, 2009
    hi...my problem with my hp printer is ...igive her an order to print it get in the paper and it don't write any letter !!!! if you have solution please i am waitting
    Thank you befor
    Sergeant:
    Champion:
  • 274 Answers
Make sure you removed the protective tape over the print cartridge head.
Here is the support website for that printer...
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodTypeId=18972&prodSeriesId=305946
Posted on Nov 18, 2008
Hi. I cannot find where to check the ink level in my deskjet 3500. Can you help me? - thanks.
When you installed the printer from the HP-supplied CD-ROM, you installed the HP Printing Assistant. Use its "maintenance" tab to check ink-cartridge levels.
Or, open Control Panel, and open Printers, and right-mouse-click the printer, and choose Properties, and you should be able to use a utility program to check the levels.
Jun 26, 2011 | HP DeskJet 3550 InkJet Printer
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
I am using HP deskjet 3550.OS:Windows 7. I would like to know if there is any settings to use black cartridge only..? When I remove colour cartridge the other black cartridge is not printing...
Hi and welcome ajithnit1 !
I know there is a trick to fool some printers like those from Brother . Maybe you could succeed with your HP unit . Here is the place where all is explained :
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
I hope this can help you .
Regards ,
fanaudi .
Feb 16, 2011 | HP Color LaserJet 3500 Printer
HP Deskjet 3550 printing yellow
Usually happens when your other inks have ran out, or your heads need cleaning, Try a couple of head cleans, or replace inks
Aug 20, 2010 | HP DeskJet 3550 InkJet Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
I have a brand-new black ink cartridge that is most definitely properly installed in my hp deskjet 3550 printer, but the printer simply will not print in black. Every document comes out blue and pink, and...
go to printers & faxies option open that just write clinck on printer icom properties prnter setings just select your both colores u have not setlect back
May 13, 2010 | HP DeskJet 3550 InkJet Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
My deskjet 3550 printed its test sheet and now goes through the motions without printing anything ie ink does not go on paper
make sure that u ink in the cartridges, u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 12, 2009 | HP DeskJet 3550 InkJet Printer
Hp 3550 printer color cartridge printing but black not printing
Perform print head cleaning and also try to take a test page and ensure that ink is properly injected out of nozzle.
If this doesnot work take out the cartridge and clean the contact and reinsert the cartridge .
Jan 30, 2009 | HP DeskJet 3550 InkJet Printer
Hp deskjet 3550 problem
Green light blinking is indicated that u r one of the cartridge (or both cartridges ) are faulty .please check u r printer with tested Ok cartridges ...it should be resolved
if this information is useful for u please Rate me .........
u r Rating is Important for me.
Jun 26, 2008 | Office Equipment & Supplies
HP DeskJet 3550 InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
