Question about Myron & Davis ADVD-270 Car Video Player
Screen My screen comes on nice and bule then goes black were you haerdly see the pitcher.
0 characters
1 Points
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
I have a jensen dvs9510. the screen opens and comes on for 2-3 seconds then goes black and will not come on. what could be causing this.
could be the park brake neutral switch so you dont watch tv and drive. just find the wire most likely brown and ground it.
Mar 15, 2011 | Jensen VM9510 Car DVD Player
I have an MMD70 player. I only get black/white on
Disassembling the unit will render the warrant void best contact the manufacture who will advise accordingly
Jun 22, 2010 | Audiovox MMD70 Car DVD Player
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
Pioneer avh-p5000 dvd'
try going to the menue screen. bottom left hit rearviewcamera. then just hit radio or dvd ect. this is a feature that is designed to view something you may be towing while driving.
Apr 03, 2010 | Pioneer AVH-P5000DVD Car DVD Player
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
To fix the pitch black screen
just take the positive cable off your battery and that will reset in to the factory settings and that should fix it
Mar 25, 2009 | Pioneer AVH-P5000D Car DVD Player
Myron & Davis ADVD-270 Car Video Player Logo
Top Myron & Davis Car Video Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
xxxxxx xxx
Are you a Myron & Davis Car Video Player Expert? Answer questions, earn points and help others
