Harwa tv childlock code
I recently bought a 2nd hand harwa 32 inch tv and when i tried to set the channels the child lock code prompt appeared and i do not have the release code or instruction manual I have recently purchased a harwa lc-32w5s television and cannot get a manual for it - when I am trying to tune in the television I am being asked for a code - any ideas??
  • jason_sol463 Dec 23, 2008
    i to have bought a 2nd hans harwa lcd tv and the child lock has been set to on and i do not have the code to turn it off
Harwa password is 000000
Posted on Apr 07, 2009
  •  Poul Kofoed
    Poul Kofoed Apr 08, 2012
    The code is ONLY 5 digits and NOT 5 x 0, 5 x 1 ...............5 x 9 or 12345 !
  •  Poul Kofoed
    After resetting the television 00000 is O.K.
Logic locked tv is locked ineed apassword
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Dec 01, 2013 | Toshiba 32AF43 32" TV
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
How to Unlock Your Apex TV When Screen is Locked
If you find that your Apex TV is showing a blank screen with a red key on the bottom left then the Screen Lock otherwise known as Child Lock or Parental Control has been accidentally activated and your TV will not respond to commands from the remote control.
To resolve this and reactivate the TV simply press the (function or F) button and hold down the mute button on the remote at the same time for around 10 seconds. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or to reset any preset rating levels.
This extract is taken from an Apex Manual specific to the child lock function;
The Childlock function is designed to prevent chiIdren from watching TV. To activate: HoId down the F button and then press the MUTE button until the symboI “ ” appears on the screen. The TV will enter the Childlock mode.
Except for the “ ” symbol the screen becomes blue or black . To unlock the TV hoId down the F button and then press the MUTE button again.
Please Note:
The Childlock can be set or cancelIed only by the remote controI. After setting Childlock, secure the remote control in a safe place.
If this Tip has helped please do take time to indicate this by using the rating buttons on the page below.
Many thanks for using FixYa.
on Dec 17, 2009 | Televison & Video
Have lexsor tv and the child lock is on and I don't have the code number can anyone help
The lexsor lcd tv is made by
I stay in Thailand and for some reason I can`t see the site in English. I bet you find your answers there...
Aug 17, 2013 | Televison & Video
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more?
Jun 07, 2013 | Televison & Video
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to :
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
Cant hear sound from tv it has channels and a childlock and needs to unlock it to listen to tv
If you have forgotten the code for the child lock then try the following:
code 0000
code 1234
try unplugging the power cord and leaving it out for a few hours to reset the internal memory.
Hope that helps. Good luck and keep us updated.
Jan 21, 2011 | Televison & Video
Child lock on
if child lock is appers press and hold menu butten in remote control more than 5 second then child lock will offf and massage will desapier
Nov 25, 2008 | Apex Digital AT2002S 20" TV
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Oct 24, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
646 people viewed this question
Top Televison & Video Experts
