Question about Panasonic PT-47WX42 47" Rear Projection Television
"Just" aspect missing?
Hi, I purchased my set from a friend of the family and it had all the aspect options functioning perfectly fine - 4:3, zoom, full and just. Several months have passed and now for some reason I cannot get the just aspect anymore. It just cycles through the other ones and does not even display this. Is there a way I can get it back, as this was obviously the best way to view many of my channels?
    Sergeant:
    Champion:
  • 375 Answers
Check your remote for possible stuck key feature.if not check the menu settings.
Posted on Sep 08, 2007
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
WHEN WE PLY MOVIE IN ZOOM THE PICTURE IS STRECH
Check for the setting of the player you are using and lower the zoom value if you can ,if not then it is normal as the full screen option does the stretch to fit the screen.
Apr 05, 2011 | Computers & Internet
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Zoom is very poor, however a family friend has the same model but seems to have an ''extended'' zoom. Is this a setting that ive missed or is the camera faulty??
The extended zoom you mention is possibly the Digital zoom.
A lot of point and shoot compact digital cameras have a basic 3x optical zoom and 3x digital zoom.... though picture quality will deteriorate once you enter the digital zoom areas.
Hope this helps.
Jan 11, 2010 | Cameras
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Web Cam Problem with the Microsoft NX-3000
Try using Skype as it is free and a really good program to communicate with family & Friends. Here is info to help.
Normal 0 Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jan 08, 2009 | Microsoft LifeCam NX-3000 Personal Web...
My plasma tv is over zooming and I cannot see any top graphics or see any words on the bottom
I'll need the model number to solve this completely, but here's the first try:
1. Check the "aspect ratio" setting. Usually there's 4 settings: Normal, Wide, Stretch, and Zoom. Flip between those to check which is best.
2. If you've got your computer hooked into it, under the options there's a "fine sync" option, that will allow you to fine-set the resolution. Use the "clock" and "h-sync" option.
Try those, and if you can give me the model number, I can be of more assistance.
Jan 04, 2009 | Panasonic TH-50PHD8UK 50 in. Plasma...
LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Nov 19, 2008 | LG 42LP1D 42 in. LCD HDTV
I receive sound and vision perfectly - the other side doesn't - any help ?
A. Skype Setup:
B. Yahoo Setup:
Oct 26, 2008 | Creative Labs Creative Webcam
Panasonic PT-47WX42 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
