Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
Upgraded desk-top software will not sync with ATT-BB-8310
I was able to make the phone sync once, at the lower left corner it acually displayed my pin instead of none. That was the fist and only time, it hasnt worked sence. I downloaded desktop (ver. v4.6).
My phone is ATT-8310 by Blackberry v4.2.2.170 (platform is 2.5.0.30)
Also are you guys aware of the new OS for the ATT-8310 and when or where it can be found.
bb expert
  • 9 Answers
SOURCE: At&T 8310 Blackberry. Delete all contact at one time, and from the sim card?
This is done in desktop manager. You have to hook your BB up to your Desktop and then go through the backup and restore process. If you need help we can show you.
Posted on Oct 09, 2008
Rayborn
  • 92 Answers
SOURCE: My blackberry is completely frozen and i cant press anything
You phone could just need a simple reset if the problem is based upon the software.
To do that click the link below to download the Blackberry Desktop Manager and the Blackberry Device Software for your Curve and run the app loader to reset your device
https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4
Posted on Jan 23, 2009
  • 173 Answers
SOURCE: How do i reset blackberry curve 8310 to factory
There is a program called "JL_Cmder". Its a Program which can Wipe or reset your phone when your phone is connected to the computervia the USb cable.
Posted on Mar 10, 2009
coldsilver20
  • 113 Answers
SOURCE: BLACKBERRY 8310 WILL NOT CONNECT TO NETWORK
follow these instructions closely and this should do the trick for ya.
from the main screen press your menue button(the one with 7 dots left of the rollerball)
the select manage connections and make sure that the mobile network box is checked and shows your network. then scroll down to "mobile network options" select mobile network and finaly select start provisioning. this should provision your new device setup with the network.
GOOD LUCK!!!! and pls dont forget to rank this solution!! :D
Posted on Mar 17, 2009
  • 173 Answers
SOURCE: Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
Posted on May 13, 2009
For got pin code
You will need to get into maintenance mode and "clear user data". Do this by touching the lower-left corner of the screen while turning on your Nuvi. Keep your finger in that corner until you are prompted to go into "Maintenance Mode". Choose "Yes" and once in the menu, choose "Clear User Data". After that, exit and reboot the unit. If the lower-left corner doesn't work, try each of the other three remaining corners until you get the right one.
Note: Any user-stored and configured data will be lost as the system is restored back into factory mode. However, it should be noted that this will not affect any upgraded map files.
Jan 25, 2011 | Garmin Nuvi 370 Car GPS Receiver
My bb 8310 AT&T device won't pair with a headset or with my ford fusion
Make sure you have the correct password for your phone. Also look in your fusion manual as to the correct steps needed.
  • Press the Power Button. // This is on a 2010 Ford Fusion.
  • Then you hit the Phone Button.
  • It should say “No Phone Paired” that means that no phone has been paired with this.
You now have a choice of options:
  1. Add Bluetooth device
  2. Connect Bluetooth device
  3. Set Primary Phone
  4. Set Bluetooth On/Off
  5. Delete Device
  6. Delete all Devices
You want to choose Add Bluetooth Device, press OK
  • Then on your mobile, turn your Bluetooth On.
  • Setup Bluetooth – Search
  • Now it’s searching for it, when that gets full, Click Sync.
  • Then you’ll want to enter the PIN number that’s on the screen.
  • Say YES to connect to Sync.
  • Now screen on dash will say your mobile phone
Mar 26, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 8310 does not sync with computer
CLICK ON OPTIONS .. SELECT USB AND CLICK on detect button . through desk top manager. the pin should be appear. on the down left side of desktop manager. if msg appears. no device found. go to Control panal . phone n modem options. click on the center tab of modems n remove any STANDARD MODEMS installed there unplug the cable n replug it back .. it ll be done . else try restart.. n dtm ll pick up the phone.
Feb 22, 2010 | RIM BlackBerry Curve 8310 Smartphone
How do I set my e-mail address to download emails
Just so everyone knows, I have BB Curve 8310 with AT & T.
You get 1 blackberry email account (in my case, it's username@att.blackberry.net). If you're like me, you have business, personal, etc accounts that you want to add without getting 20-30 minute delays before the email hits your BB.
Let's say you have 2 emails you want to set up (1 for your business and 1 personal). Let's say your business POP3 email is myname@mybusiness.com.
1) Create a username with your ATT BB address (let's say, mybusinessname@att.blackberry.net).
2) In your POP3 email settings, choose to "redirect" or "forward and save a copy in Inbox" and forward your emails to your ATT BB address (mybusinessname@att.blackberry.net) you've just created. This will help get your emails to your BB pretty much instantaneously. And emails will be kept in your inbox for you to reference as well.
3) Log into your providers BIS (short for Blackberry Internet Service). ** Can't post a link but you can just Google your providers name followed by Blackberry Internet Service and you should find it
4) Once you're logged in, from there you can set up your account.
• Email Account Name: put your ATT BB address in there
• Reply To: This is where you can put any email address you want. So, even though you're sending the email from username@att.blackberry.net, the user will see whatever email address you put in this field. So, in this case, you want to put myname@mybusiness.com. So, the user will see it came from myname@mybusiness.com and when replying, they will reply to myname@mybusiness.com (which is then forwarded to your ATT BB email, which is then forwarded to your BB).
• Auto BCC: The only problem with doing this (and I run into this a lot) is that since I'm sending out so many emails - some from BB and some from my office computer, I don't know what I sent to people, and without an Enterprise server, it is not automatically synched with my desktop in my office. What you can do here is set up a Gmail account and name it mybusiness_dump@gmail.com and any email you send from your BB will be sent to this email address as well so you know what you sent people.
• Signature: You can change your signature for each of your email accounts (business, personal, whatever), which is great.
Nov 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
How to set up sync between blackberry 8310 with outlook 2007 contacts
you have to open your blackberry desktop manager software. goto synchronize, and then configure synchronize and then tell the desktop manager to sync with outlook for you contacts calendar and so forth. so from then on when you plug your bb into your pc and strat up desktop manager, when you choose to sync it will sync your bb with outlook.
Oct 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
How to change the email address on my phone blackberry 8310, I bought it from a friend and his email address is still in the phone and I want to add my own.
Sir if you connected to the same carrier call the service provider and change it to your name and delete the accounts that has been created on that BB 8310 device and add your email address to recieve the mail. If you are into another carrier ask your friend to release the PIN and IMEI no(get the unlock key for the device) from thier side and once the PIN and IMEI is released call your service provider and they will register the BB HH using the PIN and IMEI no and integrate your email accounts and start recieveing mails.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Caalendar on my desk top for my blackberry curve 8300
the blackberry will be using the Outlook calendar to update its information. its quite easy to use. What's happening is that the items calendared on the BB are syncing with the "private" calendar under the username (Outlook Today - Username - Calendar), and not the "public" calendar (All Public Folders - John Doe). No items are marked as "private" on the BB.
Install the Blackberry Desktop manager software and after its done go to the Syncronize Button. Once inside look to the left for configuration synchronization click this button it need you to be online to do this as well. inside it will list the many programs that can be used to sync your blackberry make sure you have already setup your outlook so that it can pick up the new settings your creating. once your all done look for the top upermost button on left of BDM ( blackberry desktop manager) and click syncronize to sync your blackberry. now once it is done your BB only needs to be plugged in and it will autosync itself. look in your outlook for new entrys and popup
Apr 14, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 8310 Network Sim Problem
you can unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry curve 8310 Unlock Code. Buy your unlock code from third party. i hope this information is help you :)Good Luck
Jan 08, 2009 | AT&T Blackberry Curve 8300 Smartphone
Applications won't go into blackberry
You haven't said which BB you are using or what you have tried already so I'll give you a general answer - if it doesn't help, please let me know and I will suggest something else.
From your computer, go to either your service provider's web site or to www.blackberry.com and find the most recent software for your BB model. Install the software onto your computer. Then connect your BB. Depending on your model, you may automatically be asked if you want to update your BB. If not, find the icon to update your software (you might be able to just sync the BB with your computer but that doesn't always work). Once you have updated your BB software, you should not have any problem adding new applications. Note that some applications can be downloaded directly to your BB; others have to be downloaded to the BB Desktop Manager on your computer and the uploaded to your BB. The application instructions should tell you which way to do it.
Jan 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
61 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
