Question about Refrigerators
Fridge only unit did not cool
Fridge unit did not cool. First repairman said evaporator needed to be replaced. First repairman returned with a second repairman who said Freon level was low. Added Freon and fridge now appears to be working. Is this a reasonable fix to the problem. There was some icing around a tube at the back of the fridge which they said was blocked. Why did the Freon level go down ? My warranty will expire shortly is this a stalling tactic until it does ? Should we be worried about leaking Freon, do they still use Freon in Fridges ?
    Director Badge:
    Uploaded 100 video answers.
  • Refrigerators Master
  • 488 Answers
How to find and fix freon leak Video. Refrigerator.
Posted on Jan 31, 2017
    Problem Solver:
  • 11 Answers
If you needed freon then there is a leak somewhere. If there is a leak, then it will happen again. The freon a refrig uses is usually R-22 which is different from the really bad R-12 that eats up ozone.
If you are near the end of the warranty, I suggest you call the manufacturer and talk toi then about the leak and get it documented and get a case number or something to say you reported the problem before the warranty is up.
Posted on Nov 18, 2008
How can I defrost my Kitchenaid Superba Freezer without unplugging the entire unit?
the air from the freezer is what cools the fridge so no way to separate the cooling process for defrost
Apr 24, 2017 | KitchenAid Superba KSRS27CN Side by Side...
What is the evaporator
The evaporator is the part of the fridge that gets cold, more correctly it removes heat. It is usually located in the freezer and a fan motor, evaporator fan, move air thru the evaporator to cool both the fridge and the freezer. Some units have two evaporators, one for the fridge and one for the freezer.
Mar 12, 2013 | Refrigerators
Fridge wont go cold
Provided that the compressor and the evaporator fan are running you might want to check the state of the condenser; check it for lint build up. If the condenser is clean, and the fridge is cooling properly, it is possible that there is a leak in the system. If you do not know how to check for freon leak, have the fridge evaluated by a repairman.
P.S. If you observe a serious build up of lint on the condenser fins, clean it first, place a thermometer in the fridge and run for a while before calling a repairman. If you noticed a great drop in temperature your problem is probably solved. Try it
Dec 12, 2010 | Liebherr Refrigerators
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have a GE GSS22KGMA side by side. Fridge gets warm at the top
Hi and welcome to FixYa. I am Kelly
I am going to paste part of your text and then reply:
Your text:
Repairman came back and replaced a small round part at the top of the evaporator (resistor??) <
{ That was the termostat}
I just read that the problem could be the defrost thermostat..
He already replaced it.
I hate to say it but is sounds like your in repairman hades.
So far I see 1. a new mother board, 2. new defrost thermostat and 3. new defrost heater element. (other than wiring that is everything in the circuit)
Either one of the 3 NEW parts is bad or...there is a partially broken wire in the circuit.
Hopefully this helps you understand. ( I know it does not fix your uint)
Thanks for using FixYa.
Kelly
P.s your words again:
one would expect this to be remedied.
You got that right!
Feb 11, 2010 | Refrigerators
Freezer is working but fridge is not cooling
is the evaporator fan (in the freezer) running? if not you cant move the cold air from the freezer too the fridge. also make sure the return air duct is not blocked. air moves from freezer, through fridge and back to freezer.
May 25, 2009 | Haier RRTG21PAA Refrigerator
Freezer on bottom works fine, fridge part dosnt
it sounds like the timer is going bad.... there is a timer that runs the fridge for 6 hrs. and defrosts for 20 mins. if the contacts are pitted ,it will run for shorted periods ..... this timer can be located anywhere from behind the unit where the compressor is to inside the regrigerator compartment ...
May 23, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Jan 11, 2009 | Dometic RM2852 Refrigerator
Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Nov 05, 2007 | Samsung RS2556 Side by Side Refrigerator
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
247 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
