I have bought the all in one driving test dvd but it will not run. i have tried going to start/run and typed in D:\setupexe, it asks me to insert a dvd into the drive but it is already in there and will not play?
    Sergeant:
  • 237 Answers
First of all, the requirements to run this dvd are:
1.55 GB with HP clips on DVD-rom or 3.66 Giga Bytes full hard-drive install
Memory: 128 MB
Make sure you have at LEAST this much space and memory before an install. A little more is needed to run the dvd.
PS Have you tried another dvd in the player?
Posted on Nov 18, 2008
I just bought a used computer to replace my current one, but when i try to start it it ask me to insert boot disk i inserted a microsoft disk and it starts and works ok but if i turn it off and take thisk...
The operating system (Windows probably) was deleted on the hard drive since it would not have belonged to you by license. You will have to install some OS to the hard drive either from Windows disks you already own or some Linux variant. Right now, the needed startup files are not present on the hard drive.
Feb 24, 2011 | Acer Aspire 5315 Notebook
Iv emachines E727 windows 7 laptop, it plays dvds fine but it wuldnt play audio cds or when you insert an empty audio cd it does not show up. pls help, what shuld i do. Iv tried uninstalling the drive...
Try Both of these steps to fix the issue.
Please press the windows key on your keyboard , hold it down, and press R
Type in devmgmt.msc and press enter
If it asks to open, click yes.
Then, you should see a list of devices installed on your computer..
Double left click the cd dvd drive choice to expand it ... Then..
right click on each listing inside the cd dvd section..
And click uninstall.
Once uninstalled. restart the computer, and test the cd drive..
It should now be working in windows normal startup!!
Then, if its still not working normally.
Go to the link below.
http://support.microsoft.com/gp/cd_dvd_drive_problems
on the page that comes up. click on the green run now box.
It will start a file download ( this file is perfectly safe as its directly from microsoft)
Once you download the file, make sure to run the file..
It will run a dignostic program that will attempt to repair and fix your broken drive!
KittyTech..
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Feb 03, 2011 | E-Machines emachines (emachinees) CD-ROM...
Can't get Dell Desktop to recognize cd/dvd on D: drive
With any computer this is a question that must be answered by those that provide the driver software. Like the number above (Dimension 3100) you should begin your search here=> Dimension 3100 Drivers that is if you have not altered the driver by putting a different player in the slot. What you need to do is test the drive using the Dell diagnostics. The procedure can be found in the CD/DVD FAQ. Run the "read test". You'll need to insert various disc types during the test. This came from Dell Forums. Click Here=> Dell Forums/Osprey and Here=> Search Results for "Dimension 3100 DVD Driver"
Hope this helps, Thanks, Sea Breeze
Jul 14, 2010 | Dell Dimension 3100 PC Desktop
Driver needed for TSST Corp CDDVDW TS-H653N SCSI CdRom Device please. DVD drive shown in My Computer, and MS says I have the correct driver for this device. But, it doesn't work.
If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive. If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement. Method 3: Try a different disc drive If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps: If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5. If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4. Method 4: Make sure that the disc is compatible with the drive Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive. A DVD disc is incompatible with a standard CD drive. A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs. A DVD disc is incompatible with a drive that does not have a DVD logo on the front. If the disc is compatible, go to method 5. If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement. Back to the top Method 5: Use Windows Update to check for updated drivers If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.com If these methods do not resolve your issue, try the advanced troubleshooting steps in this article. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, or you might want to contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ If methods 1 through 5 did not resolve the issue, you can follow these methods to try to isolate and resolve the problem. Method 1: Test the disc by using the command prompt to copy files Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive. To test the disc by using a command prompt to copy files, follow these steps: Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files. Click Start, and then click Run. Copy and paste (or type) cmd in the Open box, and then press ENTER. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:*.* HardDiskDrive:cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder. Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files. If you are asked whether cdtest specifies a file name or a directory name, press F. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER. If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement. To continue trying to isolate the problem and test the CD or DVD drive, go to method 2. Method 2: Test the CD or DVD drive in a "clean boot" state If the disc is readable and undamaged, there may be some hardware or software that is interfering with the CD or DVD drive. You can test this by inserting the disc into the drive after restarting your computer in a clean boot state. This helps you determine whether any hardware or software is interfering with the CD or DVD drive. To test this, follow these steps: Restart the computer in a clean boot state. Note For more information about how to start Windows with a minimal set of drivers, click the following article number to view the article in the Microsoft Knowledge Base: 310353 How to configure Windows XP to start in a "clean boot" state After the computer is restarted, exit all programs and applications that may be using the CD or DVD drive. First, right-click each icon in the notification area, and then click Exit. Note The notification area is located at the far right of the taskbar, near the clock. Some programs that are listed in the notification area do not have an Exitcommand. Therefore, you may have to click Quit, Close, or Disable, depending on the commands that are available for that program. Click Start, and then click Run. Copy and paste (or type) taskmgr in the Open box, and then press ENTER. Windows Task Manager opens. Click the Applications tab. If any programs appear in the Task list, click the name of the program to select it, and then click End Task. Repeat the previous step until the Task list is empty. Close Windows Task Manager. Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, there may be other programs preventing the drive from reading the disc. Go to method 3. If the CD or DVD drive still cannot read the disc, go to method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the "Next Steps" section. Method 3: Change the CD or DVD drive configuration If there are programs that are preventing the drive from reading the disc, you can try to resolve this issue by configuring the drive to run in direct memory access (DMA) mode. DMA mode is a high performance mode for transferring data to and from devices. These include CD and DVD drives. To configure the CD or DVD drive to run in DMA mode, follow these steps: Configure the CD or DVD drive to run in DMA mode. For more information about how to switch your computer's disc drive controller to DMA mode, click the following article number to view the article in the Microsoft Knowledge Base: 310751 Device settings are hard to find in Windows XP Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, you are finished. If the CD or DVD drive still cannot read the disc, try to troubleshoot DVD components by using method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the “Next Steps” section. Method 4: Troubleshoot DVD problems If the advanced troubleshooting methods 1 through 3 do not resolve the issue, and you have problems specifically with a DVD drive, follow these steps to try to isolate and resolve the problem. Prerequisite You must use a DVD drive with a DVD logo on the front, not a standard CD drive. Step 1: Unplug any cables that are connected Unplug any cables that are connected to the video outputs of the computer. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, you may have problems with the video hardware installed on your computer. Contact the manufacturer of the video hardware for support or for a replacement. If the DVD drive still cannot read the disc, go to step 2. Step 2: Update the DVD driver Contact the manufacturer of the DVD drive to obtain an updated driver for the DVD drive, and then follow the manufacturer's instructions to install the driver. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated driver. You are finished. If the DVD drive still cannot read the disc, go to step 3. Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder Contact the manufacturer of the DVD drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer's instructions to install the decoder. Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated DVD decoder. You are finished. If the DVD drive still cannot read the disc, make sure that the sound card in the computer is compatible with the DVD drive. To do this, contact the manufacturer of the sound card. Reinsert the disc in the DVD drive.
Feb 27, 2010 | Compaq Computers & Internet
Hi my drive will not run any discs that i insert it just opens again and asks me too insert a disc
Either you are inserting the incorrect media type for that drive, or your drive is defective and needs to be replaced.
Nov 04, 2009 | Compaq 214799-001 ATA/ATAPI-4 9.4GB...
When i start-up my toshiba satellite m100 it ask to insert media
try to remove the media player form the.. system, sturt up..
Go to start, run, type msconfig then enter, then remove sturt up then ok
Jun 07, 2009 | Toshiba Satellite M100 Notebook
I am trying to load on D;/setupexe but it will not install.
I'm presuming this is an optical disk (CD or DVD) containing (printer?) software you wish to install ... right?
If so, are you trying to launch the "setup.exe" file from a cmd/Command Prompt shell by typing it in, then "enter"? If so, the most glaring problem is typographical error ... "D;/setupexe" > should be "D:setup.exe"
If not the above, does any installer dialog (i.e., window) display soon after inserting the disk into the drive? If the disk does indeed contain a software installation package with a "setup.exe" file, then this likely indicates "autoplay" is deactivated for that particular drive. If this is the case, it can be corrected by right-clicking the subject drive icon and modifying the settings on the "Autoplay" tab. Or alternatively accomplshed using "TweakUI". It's available at http://www.softpedia.com/get/Tweak/System-Tweak/TweakUI.shtml. However, get this handy and dandy Microsft utility regardless of this situation if you don't already have it.
This leaves the last scenario: Are you maually trying to launch the file by clicking on it? If so, what error dialog(s) are you encountering and what EXACTLY does it say?
TIP: A very rudimentary way to test the readability of a CD/DVD disk is to insert it into a drive, then launch "Command Prompt" and type in "DIR /S DRIVE_LETTER:" (without quotes), then hit enter. EXAMPLE: DIR /S D:
If it successfully displays every file on the disk (implies it's read), it's a fair indication of A-OK readable status.
That's the best shot in the dark I can make with the limited amount of info provided in the question. Please respond with additional info/feedback in order to help zero in on defining the problem.
"Today's the best day of my life...and NOW you're part of it!"
Dec 12, 2008 | Lexmark Office Equipment & Supplies
DVD/Cd Burner won't run programs.
All you need to do is that put the CD in the CD/DVD drive that you have access and not properly closed. For example here is the situation. I put a cd installer with a file named in the cd setup.exe and it is located in drive D: i access the file setup.exe and I run it or install.. then I decided not to install the programs.. what I did is that is did not cancel the installation but rather I immediately open my cd/dvd drive and get the cd..
What are going to happen? the installation is in the process and I did not cancel the installation properly. In the installation logs of the windows it still have to install the programs but it cannot find the file setup.exe that is located in the Drive D:.
Try to put a cd in your cd/dvd drive with file named setupexe on the cd.. that will solve your problems. TY
HOPE I CAN HELP
Dec 05, 2008 | Acer Aspire™ T180 PC Desktop
Cannot install windows vista ultimate 64 bit on my computer when I have xp installed. Can boot from the 32 bit version disk though but I want the 64 bit. Tried booting it from start-up by booting from CD...
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
    Note When you receive with the Get important updates for installation message, click Go Online.
  5. Click Upgrade when the Which type of installation do you want? screen appears.
    If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
  6. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Nov 27, 2008 | Computers & Internet
Actived webcam
I just bought a new web cam, i was having a hard time installing it. The pc can detect the web cam but it cannot install the drivers.
MAKE SURE THAT THE DISC THAT CAME WITH THE WEBCAM HAS DRIVERS IN IT.
1.Insert disc, right click your cdrom drive(example D:) then click explore. There must be a folder for drivers. Sometimes the setupexe file is not enough to make the webcam work
Mar 12, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Alun Cox
David Payne
David Payne
