Question about Sony Handycam DCR-TRV320 Digital Camcorder
Playback is very jumpy! just gave it a wack and it worked?
After tapping the top of camcorder it now does not produce any video, have tried tape cleaners, any help much appreciated! I have over 200 tapes do you know if there are any converters to a vhs or burners to dvds? Thanks Rick Trevena ps no self diagnostic displays
  • 30 Answers
Hi Rick, There are no converters to vhs or dvd. You would have to dissassemble the unit, remove all connectors and then re-seat all the connectors rhat you removed. Assemble unit and test. This could solve your no video playback problem.
mr cicmo
Posted on Nov 18, 2008
On my Sony Hi 8 Camcorder every time I try to record or play a tape,it does'n't play and only appears c:31:23
This error comes due to missing reel pulse of mechanism, remove battery/ power source from camcorder and tap gently top cover of camcorder with your palm few times, reattach battery and check playback.
Hope this will solve your problem.
Let me know if you have additional question.
Thanks.
Dec 12, 2010 | Sony Hi8 CCD-TRV138 Camcorder
My sony wount record or playback a movie, there is a blinking symbol when i hit record.
I'm Sony tech and can help you to solve problem of CCD-TR818 camcorder.
Tap bottom of camcorder few times with your palm gently, now check playback of tape.
If problem still not solved, let me know what error code flashing on top right of view finder screen.
Thanks.
Dec 04, 2010 | Sony Handycam CCD-TR818 Camcorder
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
My camcorder's tape playback is jumpy, like it's not tracking correctly.
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 16, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Black lines across the screen of JVC GR-D870U camcorders.
Same issue here...started when I hooked to the laptop to download videos.
Jun 08, 2009 | JVC Video Cameras
Stuck Tape in a Sony TRV460
Gave it a good wack on the tape side & out it popped!
Mar 25, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Playback jumpy
NO.PLEASE TRY TO CLEAN THE DRUM ASSY
Oct 16, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Black bands and skipping in playback
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
Apr 02, 2007 | Panasonic NV-GS11B Mini DV Digital...
Jumpy Playback Through TV
First you should try a couple other tapes to make sure they all do it. It could be tape damage on the tape you are using. If you remove the tape from the unit and look at the part which gets inserted first you will see a small latch on the front side of the door. If you depress the latch you can open the cover over the tape. Be very careful and don't touch the tape! Look at the tape for damage. If it is perfectly smooth, like a mirror, it is OK and the camcorder has a problem. If the tape is OK you probably have a tape path problem or the unit could be dirty. Cleaning the heads would be the easiest solution to try but if you are not familiar with the process you could do more damage than good. If you know how to properly clean the heads, certainly do that first. If that does not solve your problem either a tape guide is not adjusted properly or the tape is not loading fully or properly in the tape path. Either way it isn't going to work until it is repaired. I'm guessing that repair would be beyond your skills. You stated that you bought it off Ebay. You should contact the person you purchased it from no matter what is wrong with it because if they presented it as a working unit they were less than truthful. Good luck.
Jun 24, 2006 | Canon ES550 8mm Analog Camcorder
Sony Handycam DCR-TRV320 Digital Camcorder Logo
137 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
