My pentus tv has just lost picture but not sound
...i've tried pushing all the wires in to no avail. we can only get digital tv where we are so i can't unplug the freeview to try that. i can't get any menu display on the tv at all. help!
  • jazzman777 Dec 08, 2008
    After a while, the picture just goes - even though there is still sound. Strangely, if I switch off at the mains, rather than the tv itself, the picture usually returns (for a while!).
    This Pentus piece of **** is just over 2 years old. I bought from Currys in Liverpool. Never again. Pentus or Currys.
    I'm told that even a diagnosis would be costly. I think I'll just take it to the tip - and read books instead!
  • 1153 Answers
SOURCE: philips 50pp9202, no picture but sound is fine.
I have the 51 inch of this model and I have found that usually it give you some indication before going completely out. Like color problems, sound, or just video disappearing. Most of the time it will be the convergence amps going bad, but you should have seen some color distortion. If not then it could be the vertical output. TDA8177 needs replacing and check caps around and diode, If not this then look for open fuse in HV line to crt's. Also power supply fuse like 1900, 2004, 1300, etc.
Posted on Sep 06, 2007
SOURCE: freeview locked
The info>menu>mute>power on takes you to the engineers menu.
(Start with the TV switched off)
Use the direction keys, down to RESET,
then the right direction key performs the reset, the TV switches off.
On power again, the setup sequence runs for both TV and DTV.
I had exactly the same problem as p111upr and this fixed it.
Posted on Dec 22, 2007
  • 12 Answers
SOURCE: lost picture and sound
clear th board with the polish
for detials:E-mail
Posted on Jan 09, 2008
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
Posted on Feb 03, 2008
SOURCE: Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Posted on May 16, 2008
Pentus TV with missing remote bought an all for one URC-3910 seems to be no listing for pentus tvs help please
Use code search-TV on your remote (One For All) to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Aug 21, 2016 | Televison & Video
Venturer Tv to Sky
It sounds like your TV is on the wrong input. Look for a button that says input or source. Depending on the TV this will either provide an onscreen menu to select an input or it will simply scroll through the inputs. Turn on the Sky box and run through the inputs until you see something that looks like your Sky Box.
Jul 26, 2013 | Televison & Video
Don't know Password for Pentus LCD TV
You enter 1234, 1111, 1147 OR 5963 , or press ZOOM button and VOL- KEY both...
Feb 18, 2013 | Computers & Internet
I lost my remote to my sanyo plasma and my picture is stuck in zoom. I've already bought a universal remote that has a pic. zoom button but does not work for my tv. How can i get my picture down t
push minue directly on tv and seif that works. try to see if you can get it out of that mode. you might need the origanal remote. try search on the remote control may work
May 16, 2012 | Sanyo DP42746 42 in. Plasma Television
I have sound on av2 from the playstation game but the picture is on av4. how can i get these two back together again i have a sony tv.
Check the connections you've used to input the device are right with the instructions for your TV.
Sounds like you're using a "higher band" analogue connection for video and the audio is a separate analogue lead.
If there's a single cable type digital connection available - on each device, of course -use that for best results or if provided a single cable analogue system like Scart if no digital input or output.
Sep 24, 2011 | Televison & Video
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
Lcd tv switches on red or blue or green
Feb 11, 2010 | Televison & Video
I cannot find a tv code for a Pentus LCD TV?
May 11, 2009 | Televison & Video
How do I adjust the picture, I lost my remote..
Sorry Bud you cant. An original remotes available at or 1800-remotes for about $61.00 + shipping. Without seeing a picture Im not even sure if thst will help ya man. If you wanna try to see if an alighnment will help then get the remote. I would advise you against doing any sort of technical alighnments as this set has high voltage around inside even afterv its been disconnected for a while. Good Luck
Jun 09, 2006 | Hitachi UltraVision 55HDS52 Television
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
